Skip to content
Fine Woodworking
Main Menu
Subscribe
GET THE MAGAZINE & MORE
Magazine Cover
  • Save 69% off the cover price
  • Or, get everything with UNLIMITED, including 40+ years of the online archive.
Subscribe Now!
Subscribe
  • Projects & Plans
  • How-To
  • Shop Tips
  • Tools & Materials
  • Videos
  • Magazine
  • Video Workshops
  • Members
  • Forum
  • Gallery
  • Blogs
  • More
    • Log In
    • Join
    Fine Woodworking Main Menu Subscribe
    Rust removal on jointer bed
    londonjoe40 | Posted in Power Tools and Machinery on April 17, 2010 12:25pm
    Dear Fellow Woodworkers,
    I have a 6″ Grizzly jointer (No. 452), which does a great job of flattening boards. Last year I put the jointer into storage because I temporarily moved oversees. Recently, I moved back to the US and I found the jointer bed lightly covered in rust from the humid Minnesota weather. Does anyone have a method of removing the rust, protecting the bed, and preserving the flatness? I would appreciate any help.
    Joe
    Reply
    X
    1. hammer1 | Apr 17, 2010 10:08am | #1
      I'm not bragging, Joe, but my table saw takes a bit of abuse. I flatten plane soles on the table extension, sometimes spill my coffee, chemicals or something else, at times it moves out to a job site and may get rained on. When it gets nasty or spots of rust, I grab my RO sander and have at it. Just sanded it yesterday with 120. I've been sanding this saw regularly since 1978, used a 505 sander before ROs were available. I've yet to sand through the original machining marks on the saw, and that could easily be 300 sandings. If there is pitting from the rust, you'll never get it out but it isn't a problem. Surface rust is nothing and is easily removed. Unless you hold the RO in one place for 8 days with a very coarse grit, you won't effect the flatness of the tables, even then you probably won't get through the machining marks. I wash up after sanding with a cloth dampened in mineral spirits and then apply and buff out a thin application of paste wax.
    2. forestgirl | Apr 17, 2010 10:38pm | #2
      Light rust? pretty easy to remove...
      If it's just light rust, you may not even need to go with power.  Just mineral spirits as a lubricant, and sandpaper on a block.  Some people use WD40 for this purpose.  I'm stocked with EvapoRust, which is generally used as a soak, but using it in a cloth laid on the surface might work, don't know though.  I'd caution against any kind of acid (such as Naval Jelly),.
    3. ThreeRiverstool | Apr 18, 2010 12:27am | #3
      Cleaning up Jointer
      Hi Joe,
      I use a orbital sander with 1500 wet dry sand paper, dry.  Tear off a guarter sheet and just turn it abrasive side dow,  Place your sander over it and just light pressure will hold the paper in place.  WIthin minutes it will polish the surface like a mirror.  Keep using the old paper and dont replace, as the abrasives wear off it continues to polish.  Use mineral spirits to clean the surface and follow up with paste wax, two coats.  The first coat will remove some residue of the sander paper left behind.  The second should wipe clean.  Anything more abrasive than that is too much for your application.
    4. londonjoe40 | Apr 20, 2010 05:44pm | #4
       I would just like to say that I am very grateful for the advice about removing rust on my jointer bed. I think that I will try using some wet-dry sandpaper with a sanding block aided by some WD-40. I'll start with rough 220 grit, 320 grit, 400 grit and 600 grit. Then, I'll put on the mineral spirits and paste wax to finish it off. I always prefer to stick to hand work when I can. If this doesn't work I'll try more aggressive methods.  Thanks again.
      Joe
    5. HomeHack | Apr 20, 2010 06:19pm | #5
      How I did it.
      Joe,
        I spent three years in Germany, upon retrieving my table saw and jointer from storage, they both had some surface rust.  I used a scotch brite pad, my RO sander and WD-40.  Hose the top with the WD-40, just enough to puddle without flowing off, and go to town with the sander.  After I hit the tops with liquid Turtle wax. I've read that car wax can stain wood , but haven't experienced it myself.  So about once a quarter here in North Tx, I wax up all my tool surfaces.  On a side note, while in the USAF, I used car wax regularly on hand tools in a humid climate and got our recurring rust problems under control.
        Larry
    6. SawdustSteve | Apr 20, 2010 10:43pm | #6
      Rust Removal
      I feel like being contrary tonight.  Fighting rust is a never-ending job, so why fight it.   I have several machine tables that I've let go to to a nice plumb brown.   Spray the jointer tables with WD-40 and then work it in with 4/0  steel wool.  Wipe everything off.  The surface rust should have disapperaed, leaving the flat surfaces with a nice plumb brown.  CONTROLLED rust.  It is actually a protective surface, not deep pitted rust, but that fine layer of rust on the surface.  After two good steel wool-ings, wipe the surface clean with any type of solvent and then give it two coats of Johnsons Paste Wax or Butchers Wax to protect the surface.    It takes a bit of getting used to, but we're always talking about the lovely pattina on wood, yet we hate to have a nice warm brown pattina on our machinery.
      There, I ve said it, and I feel much better for it.
            SawdustSteve    Long Island, NY  (E of NYC)
    7. User avater
      RonInOttawa | Apr 20, 2010 11:17pm | #7
      I'm a fan of keeping things simple.  Wet the surface with WD-40 and go at it with a ScotchBrite pad after giving it 5-10 minutes to soak in.  I think you'll find that this will remove between 95% and 100% of the rust unless it has progressed to the point of pitting the surface.  Feel free to go after anything left with an ROS and 150 paper.  You will be dealing with small areas and if you do happen to remove a bit of iron it won't affect the overall flatness of the table.  The wood will be sliding over a hole rather than a bump.
      Ron
      1. pcott | Apr 21, 2010 05:12pm | #8
        I just remove rust with steel wool. then I use waxit to keep it away.
    Log in or create an account to post a comment.
    Sign up Log in
    Start Your Free Trial
    Subscribe to Fine Woodworking
    Save up to 56%
    Subscribe
    Related Posts
    • Rust removal & plastic tool handles
    • Rust prevention
    • Craftsman Contractors Series Table saw 113.299410 with XR-2424 Fence
    • bandsaw rebuild
    • Table saw spinning the wrong direction.
    Categories
    • Business
    • Finishing
    • General Discussion
    • Hand Tools
    • Jigs, Fixtures, Tips & Tricks
    • Joinery
    • New To Woodworking
    • Power Tools and Machinery
    • Project Plans/CAD Software
    • SketchUp
    • Turning and Carving
    • Wood and Materials
    • Workshop
    Recent Posts and Replies
    View More Create Post
    Member Exclusives
    More Member Exclusives
    • How to Make a Tabletop Float
      Simple and sturdy joinery allows the top of David Welter's table to float without overshadowing the rest of the design or blocking the flow of light between base and top.
    • tune up block plane
      How to tune up your block plane
      Whether your block plane is new or vintage, follow these steps to get it running at full capacity.
    • Simple dovetailed Box
      Milling Stock for a Dovetailed Box
      How to mill parts for a box that are straight, flat, and square.
    • wiping varnish finish
      How to brush on a varnish finish
      A wiping varnish goes on easily and creates a tough surface ready for rubbing out.
    • Shape Your Skills
      Plus tips, advice, and special offers from Fine Woodworking.
      Sign Up
    • Shop Talk Live Podcast
      Our biweekly podcast allows editors, authors, and special guests to answer your woodworking questions and connect with the online woodworking community.
    • Woodpecker Sweepstakes
      Woodpeckers Shop Upgrade Giveaway
      Enter now for your chance to win more than $2,000 worth of woodworking equipment from Woodpeckers. Click for full details.
    • Staff Picks Blog
      We have created these special content collections organized to give you a deep dive into a range of topics that matter.
    From the Store
    View More
    • The Why & How of Woodworking
      Buy Now
    • 52 Boxes in 52 Weeks
      Buy Now
    • 2020 Fine Woodworking Archive
      Buy Now
    • Complete Illustrated Guide to Woodworking USB
      Buy Now
    View More
    Get the latest from Fine Woodworking Magazine
    • #289-May/June 2021
      • Arts and Crafts coffee table with story-book charm
      • Links from Fine Woodworking issue #289
      • Seven tasks for a block plane
    • #288-Mar/Apr 2021
      • Phil Lowe: A craftsman and gentleman
      • Online Extras from FWW Issue #288
      • Phil Lowe: craftsman, teacher, friend
    • #287-Jan/Feb 2021
      • Simple, handsome 17th-century box
      • Online extras from FWW issue #287
      • Editor's letter: Finding sanctuary in the shop
    • #286-Tools & Shops 2021
      • Shoulder plane setup and use
      • Online extras from FWW issue #286
      • From the editor: A shop to call home
    • #285-Nov/Dec 2020
      • Make a dovetailed desktop organizer
      • Online Extras from FWW Issue #285
      • Announcing FWW ambassadors
    UNLIMITED membership - Get access to it all
    Start Free Trial Upgrade Membership
    Fine WoodWorking
    Follow
    Newsletter
    Get woodworking tips, expert advice and special offers in your inbox
    Sign Up
    Membership & Magazine
    • Members
    • Digital Libraries
    • Join Unlimited
    • Magazine Subscription
    • Magazine Renewal
    • Gift a Subscription
    • Customer Support
    • Manage Preferences
    Taunton Network
    • Fine Homebuilding
    • Green Building Advisor
    • Fine Gardening
    • Threads
    • About
    • Contact
    • Advertise
    • Privacy Policy
    • Careers
    • Copyright
    • Terms of Use
    • Accessibility
    • California Privacy Rights
    © 2021 The Taunton Press, Inc. All rights reserved.
    Get instant access to over 100 digital plans available only to UNLIMITED members. Start your 14-day FREE trial - and get building!
      Main Menu
    • Projects and Plans
    • How-To
    • Shop Tips
    • Tools & Materials
    • Videos
    • Gallery
    • Magazine
    • Video Workshops
    • Members
    • Forum
      Popular Topics
    • Design
    • Small Projects
    • Beds
    • Chairs, Benches And Stools
    • Built-ins
    • Storage And Shelves
    • Cabinets
    • Carving
    • Casework
    • Desks
    • Tables
    • Shop Storage And Furniture
    • Woodturning Projects
    • Workbenches
    • Surface Prep
      More
    • TV
    • Forum
    • Blogs
    • Webinars
    • Podcasts
    • Customer Support
      Account
    • Log In
    • Join
      Magazine
    • Current Issue
    • Past Issues
    • Digital Libraries
    • Magazine Index
    • Subscribe
      Membership
    • Member Home
    • Start Free Trial
    • Gift Unlimited
    • Log In
      Shop the Store
    • Books
    • DVDs
    • Taunton Workshops
      Events
    • Fine Woodworking Live
    • Fine Woodworking HANDS ON
      Account
    • Log In
    • Sign Up
    Newsletter
    Get woodworking tips, offers, and expert advice in your inbox
    Sign Up
    Follow
    UNLIMITED
    Upgrade Membership
