I am interested in adding a router table setup to my workshop. I have a unisaw with a Biesemeyer fence with a 50 inch extension table. Is there anyone out there who has strong feelings about me integrating the router into this table as opposed to buying or making a separate router table?
Put your router table where you want it. Keep the first one simple so if it doesn't work out: Scrap it.
More on the fixture at the RT link.
There are only a few issues with a router table mounted to the saw. The table top has to be strong enough not to sag over time with the weight of the router. Some newer fence systems only have a front rail to mount to. Saw fences are not particularly useful for routing, so, you often add a split fence in addition to the normal rip fence. There can be cases when either the router set up or the saw set up interferes with the others operation. One or the other will have to be moved but, for me, this isn't very frequent. My table saw is well lit and has an outfeed table, these are handy with the router table, plus there is dust collection to the saw which is easy to tap into, temporarily or permanently. A saw mounted router is a big space saver in a small shop, especially since the lighting and support are already there. I mounted a switched outlet to the table which makes it easy to unplug for bit changes and provides additional linked power for things like a stock feeder or vacuum.
Wood tables can change in dimension with the seasons. Depending on how your table is made and mounted, the changes can affect the saws rip fence accuracy. I have several router tables plus my shaper will accept router bits. Most of my tables are simple boxes that I clamp to a workbench or can take to the job site. It's nice to have a couple of tables when making things like paneled doors. One set up for the bead, one for the cope. You don't have to change bits and if you goof something up, you can go right back to the original set up. I like my router mounted on the saw, when it becomes a problem, I have other options.
I appreciate both answers to my question. Thank you for your time and interest. Perhaps it might be best to build or buy a separate table. All the best.
I have had a combo Unisaw/router table setup in use for 5 years. It has been a good investment for two reasons:
1. It saves space and
2. Iit gives me a large work surface to support table tops, etc. when forming large bit edge treatments.
I have converted my saw table to a 60" x 60" surface, with the outfeed extension cantilevered out from the saw mobile base. The router insert is mounted diagonally from the saw surface. I can move the entire package with one hand if I need to reposition it. The cantilever suport is made of 1" angle iron from the hardware store; no welding. The worksurface is 3/4" plywood with many coats of poly.
The only change I would make is to go with a thicker surface so I would be more comfortable installing Tee Track.
Jerry
Jerry,
This sounds quite appealing. If I understand you correctly, you have a "router table" which is cantilevered off of the extension. This means it is diagonally placed to the saw? When not in use, you can lower it just like I can with my outfeed table? I hope I am picturing this correctly. Thanks for your reply and any further answers, as well.Jim
I would say which way you go depends on how much shop space you have. If you have lots, then I think you would find a separate router table most convenient. If you're short on space, then somehow combining the router with your TS set up can make a lot of sense. But it is true, as others have said, the two can conflict with one another. I had this arrangement for a while years ago, and then abandoned it for that very reason.********************************************************
John Wooden 1910-
The best way to picture it is to visualize a 60" x 60" table - on casters. (If I knew how to attach a photo, I would.) The saw and right hand saw extension are 1/2 of the table. The other half is the plywood surface I mentioned. The portion directly in line with the saw serves as an outfeed table. The portion in line with the saw extension contains the cutout for the router. Tee slots are routed in to mount my Jessem router fence.The entire plywood extension is supported by three angle-iron legs which run from the outer edge of the plywood at a 45 degree angle down to the mobile base of the saw. It is really solid! I have no problem stacking milled project pieces on it because the saw itself is so heavy and solid. If you want some photos email your address to me at "[email protected]" - or tell me how to post some photos.Jerry
