Hi, this is my first query, so bear with me. I am seeking advise on building a router table. I have an old Stanley 2 horse router that must weigh about 15 pounds and has so much torque that when I turn it on that it almost twists out of my hands.As a result it sits on the shelf most of the time because it is so cumbersome to use. I am thinking of building a table for it. The table would be two pieces of 3/4 inch Baltic Birch plywood glued together. I have not decided what kind of mounting plate to use or what kind of fence to make for it. I have in mind using it mainly to make glue joints with a huge glue joint bit and to keep it permanently mounted in the table. I have looked over commercial tables for ideas and the only one I like is the cast iron one from Nucraft.(I dont care to spend that kind of money on a router table.)
Since it doesn't have soft-start (and I'd guess doesn't have variable speed either) your situation would be improved with a speed control for the router. Most catalogs carry these, and they come in 15amp and 20 amp versions. Cost is between $19.99 and $29.99. You could use this to solve the start-up torque problem by adjusting it to a slower speed for start-up, then cranking it up to whatever speed you need before starting the work.
I used mine for the first time recently, and found it to be immensely helpful. (after shattering a straight bit on some oak, I consider the variable speed to be a primary safety device)
Can't help with the router plate -- I'm saving up for the Veritas table and quit looking after I decided on that beauty.
Edited 8/9/2002 9:24:47 PM ET by forest_girl
You only need double thickness if you're adding a mitre slot, otherwise you can frame out 3/4 by itself. I used quality paper faced ply and then varnished right over the paper. Made for a really good surface. I had a mica covered one and didn't like it because it was too slippery. I prefer a little drag.
i also used 3/16" aluminum plate for the base after breaking several acrylic ones. I made it rectangullar so I don't have to f ight the handles getting router out of the hole. A larger base plate is nice because I drilled a series of holes in it and use it as a trammel point for cutting small circles by just inserting a screw. Plus, it never breaks or sags.
I also have an ancient Black & Decker with more torque than a helicopter, but it still works fine in the table. No big deal because I'm not holding it when I turn it on.
Have fun with your table: you'll probably make a half dozen of them until your done and discover that any old table will do as long as it is big enough. After 15 years I'm still using a hunk of wood with a bolt through one end and a clamp at the other for a fence.
Thanks none, I'll pass all that info along to Tim (LOL! tongue-in-cheek)forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Gotta be careful where you click around here ;-0. Just neverknow when yer gonna do the wrong thing.
Hey, I saw your pix of the router lift. I didn't understand the point of that -- could you explain?
BTW, I'm Dave, not "none" (at least not none yet). I screwed up on registration and can't find a way to correct it.
Dave of Florida as opposed to PA. Dave and WA Dave and all the other Daves.
Hi Dave of Fla, I'll try to remember! The router lift pics were from S4S if I remember correctly -- he had posted them as attachments, but the were super-big files, so I edited them for him and posted them directly into the message.
You can go back and change your nickname -- what'd you do, type "none" in the box? That pretty cute! Click on "My Forum" and when the page comes up, click on "My Preferences" and go down the page to the nickname box and type something in there -- it should change to your new nickname at some point. Or, if you've grown fond of "none" you could just add a signature (further down the page, almost to the bottom) "Dave from FL" or whatever. I try to always look in a poster's message to see if there's a "real" name I can use when I address a response, some have 'em, some don't.
I'm glad you're not really none yet!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
No, I think I just failed to put anything in that box. I tried once to correct that couldn't see how. Thanks, I'll try again.
I was asking about the router "lift" because I didn't understand the reasoning behind it.
Dave of Fla.
Hi Dave, if Mark hasn't left for the weekend, you could contact him for help on the name thing: mailto:[email protected]
I'm assuming that S4S's router lift is to facilitate raising the router height without actually bending over and underneath the table. I've seen designs for home-made router lifts in magazines, but never been inspired to make one myself.
Hope your weekend is good!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I've used Woodhaven's phenolic inserts to mount routers in shop built tables. I got started on this type when they came out with a leveling system some years back. For a few bucks they'll sell you a template for cutting the hole that will fit their plates and you then attach the leveling bars under the table. It's an easy to install, reliable system that I've found to be a good value. If you want to buy a pre-built table, fences etc., they've got it all. I've always made my own, but if you want one of the extruded aluminum fences with the integral stops and other gadgets, Woodhaven has been around and has gotten good marks for the items they sell.
Tim -
This is my somewhat unusual solution for a router table. I just embedded it in the end of my rolling workbench. I have a 4" duct underneath hooked to my 1200 cfm DC. The space underneath is inclosed by a 12"x12"x12" box made of 1/4" plywood. I clamp boards from one side of the workbench to the other when I need guides. I will say that it definitely is stable! A switch on the side of the bench turns it on and off. Has turned out to be quite useful. See the pic.
PlaneWood by Mike_in_Katy
PlaneWood
