Hi Ernie.
I recently purchased a router handplane and was wondering, given the odd-shaped cutter, what you would recommend as the best technique for sharpening. Thanks.
Hi Ernie.
Router planes are handy for cutting dados, inlays, hinge mortises to depth and even cleaning up the cheeks of a tenon. Known for centuries they were first made in wood and often referred to a “Witches Tooth” due to the hag tooth nature of the cutter. This hag tooth is, however, a bit tricky to sharpen. I like a set of three ceramic stones (coarse medium and fine) for this job as they are very durable—virtually immune to wear. Gripping the shank of the cutter in a vice I dress the top of the cutting edge (the bevel) with each of my three stones in turn. I hold the stone in both hands and use them much like I would use a file. Removing the cutter from the vice I then set the bottom flat on the stones and bring it to a polish. The bottom of the cutter is on an upward slope of about 10° to provide clearance during cutting. Only putting the bottom edge down flat insures that this critical angle is maintained.
