I would like to get a small router to use for cutting the dado in which to lay string inlay. Does anyone have any recommendations?
almost any small router will work. even the little dremel is a good tool. what you really need to consider is the availability of a good plunge mechanism and edge guide. in my opinion, the best aftermarket maker of both of these is made by microfence.com
you will also want a good supplier of carbide end mills which can be had down to the size of a human hair! give me a bit and i will look and see where i get mine from.
chris
I use a Dremel Tool fitted with their plunge base. I also use a DeWalt laminate trimmer, but only when visibility isn't important, because of the restricted view of the bit .
Rob Millard
you might also look to stew-mac - stewartmacdonald.com I think? they sell instrument maker wares, especially guitar related. They have a real nice base for the dremel body. And probably a few other things you never knew you couldn't live without.
Real trucks dont have sparkplugs
That is a very cool site, thanks! forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I have the StewMac precision router base and have used it with a dremel for a while. It has worked well for me doing intricate inlay on a banjo fingerboard. StewMac also sells tiny down spiral bits. I've used the 1/32" extensively. I've also tried 1/64" bits but found that they broke too easily.
Here's a StewMac dremel base on eBay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220435787373
I have a dirt cheap Harbor Freight laminate trimmer mounted on a Shopsmith lather faceplate. With the Shopsmith in drill press position, I use the trimmer like an overarm router. The best feature is unobstructed view of the cutting bit while in operation. I assume any drill press can be used IF you can lower and lock the quill.
I'd love to see a picture of that!The nine most terrifying words in the English language are, 'I'm from the government and I'm here to help.' - Renaldus Magnus
