I am in desperate need of a window sash bit (or pair of them) which has a profile depth of 3/8 in instead of the usual 1/4 in depth. I have used the Amana sash bit 55340 for literally thousands of feet of sash, but the architect for this historic renovation insists on 3/8 in profile. Like the Amana 55340 it must be able to handle 1 3/4 in stock. I don’t feel like I’m to resourceful in this field, so if anyone can direct me to a manufacturer, distributor, or fabricator it would be greatly appreciated. Surely this bit is out there somewhere
Thank you for your consideration Dick Fox
Moved Post-Need router bit source
I can't claim any great expertise on finding some of the more obscure router bits so I moved this into the Power Tools section where hopefully someone can help you out.
John W.
Router bit question
Thanks for watching out for me John. Nearly every company makes a window sash bit, but they all have a 1/4" profile depth. My requirement is a 3/8" profile and the ability to make 1 3/4" sash material. Thanks again Johb - - -maybe the right person will read this. Dick Fox
The Amana 55340 bit is 1 13/16" tall and should be good for 1 3/4" thick stock. I checked my catalogs and did not find any taller bits.
Not a Problem
You can have custom pattern router bits made as you need them by almost any reputable tooling vendor. I like Gharles C G Schmidt in New Jeresey. BigBitCo will not be interested.
Send them an accurate drawing of what you want, shanks size, rotation, etc, and they will quote it. I find it advisable to buy two in case one gets destroyed somehow.
Or - You can be adventurous and order HSS blanks (Forest City Tool) and grind them yourself.
With router bits, they are so cheap, the first job usually pays for it.
Dave Sochar
http://www.acornwoodworks.com
