Riving knife can be added to cabinet saw
At the tool store yesterday looking at the new General cabinet saws. Pulled the throat plate to see the clean simple design that general has used to add the riving knife – very well done. Just can’t imagine why there has been this declaration for years that “you can’t add a riving knife to a cabinet saw”. It’s a simple thing, someone just had to do it.
OK, how would I do it on my PM-66?
I think it would be simple for a company such as Powermatic or Delta to make a retrofit riving knife of similar design to General - if they wanted to.
Here's the General manual http://www.general.ca/manuel/650R-T50_EN.pdf
Looks as all that's needed is to change the arbour bracket and add the riving knife mechanism.
Edited 3/27/2009 1:29 pm ET by EdgeGrain
Might even be able to install one from General -- but it would be a helluva job to get access to the arbor and drill and tap the holes, at least for me. Thanks.
I'm told General offers a retrofit kit for their saws now.
When a friend of mine asked about a retrofit for an older General a year or so ago he was told that it was going to cost upward of $700. He suddenly lost interest. Given the amount of change required to the arbor assembly, and the limited market, such a pricetag is really no surprise.
Jim
You can't add a riving knife to an older style cabinet saw because the knife mount needs to raise and lower with the blade, which wasn't possible with the older saws. To get the blade moving with the blade the entire blade and arbor mechanism needs to be reengineered.
John White
Shop Manager for FWW, 1999-2007
Actually, if you look at the General drawings they have simply machined a boss on the arbor bracket casting to mount the riving knife mechanism. They have not reengineered the saw.
I understand the retrofit kit is 500.00
Edited 3/27/2009 6:18 pm ET by EdgeGrain
Bob Ross has developed a device called the Bolt On Ripping Knife (BORK), which attaches to the arbor swingarm of an existing cabinet saw. The knife mimics a riving knife...it attaches directly behind the blade, and travels up/down and tilts with the blade. The biggest difference between the BORK and a true riving knife is that it travels in a slight arc due to being on the end of a swing arm, as opposed to straight up and down with a traditional riving knife. I've had one in my Shop Fox W1677 since August and it works well. It'll also fit the Griz 1023 and the Craftsman "zipcode" saws, among others.
I also have a BORK on a 70s vintage Unisaw and it has performed well. I did have to make couple modifications but they were relatively easy to do. I couldn't get full blade height as the bracket was hitting the bottom of the ZCI I had made.
The long bolt on the bracket had to be shortened (hacksaw) and the bracket had to be bent. Wasn't sure how to go about this but a phone call to Bob and life is good. Just to be sure I took the bracket to a friend with a horizontal metal cutting bandsaw to remove the small wedges of metal so we could bend the bracket. Didn't want to cause the bracket to go out of alignment.
How much does the BORK cost?
I wonder if I can put one on my Delta Cabinet Saw?
Frank
I paid $100 and here's Bobs WEBsite: http://shop.walnutacrewoodworking.com/main.sc;jsessionid=7CC8B391389EAF756D76C655CE9F84F2.qscstrfrnt01
