Hi,
Have been working on the restoration of a vintage 1917 trolley car. There is extensive use of cherry wood in the interior panneling and window frames.
Much of the cherry has been discolored due to minimal maintainence and neglect over the years, a coating of grime, sun exposure to certain areas and staining from condensation on the window frames. We can not expect to bring the color back to new but would like to at least lighten it and make it more consistent. The wood has been stripped to bare and cleaned.
Any ideas guys???????????
Hank K.
Hank,
A light sanding, and a treatment with oxalic acid solution might lighten up the staining. If that doesn't work, a two part bleach will lighten all the wood, but may not leave it an attractive color. Cherry naturally darkens with age, so bleached, it may appear un-natural.
Hi,
Oxalic acid seems to be the consensus. We will try it out on the back of one of the panels as a test. Thanks for the input.
Hank
Oxalic acid will remove rust stains nicely. It won't really bleach the cherry too light. You'd need peroxide for that. A wash with dilute lye will darken it up considerably. Needs to be well washed and neutralized after that. For a big area, just a light bleaching and letting it sit for a while before refinishing may be best. If you want it all very even in color, a light sprayed coat of dye would be best. It will have a fair amount of color variation if you only let it darken naturally.
Thanks Bob,
Is drugstore peroxide strong enuf? Just brush on? Is there a neutralizer to follow?
Thanks again
Hank
Commercial wood bleach is about 20% peroxide. Drugstore variety is around 3% I think. It may do something, but not a lot. Also, peroxide bleach is mixed with an equal amount of lye solution just before use. Makes it work much better. Many paint places sell the 2-part peroxide bleach. Something like $10 a quart. Industrial suppliers sell it in larger sizes. Oxalic acid will clean and remove rust stains, oxidation. It won't bleach nearly as much as peroxide..
I think Ray is right-- clean off the grime and everything else-- might need a solvent to remove the oils ( body ,etc. ) let it dry good to tell if you need to repeat then if there are still any un=natural discoloration ( remember cherry will naturally be dark not black but a very rich mahogany red appearance ) If you are trying to make it look like 15 year old cherry go to my e-mail and I'll tell you how I do it [email protected] good luck
