I am replacing stair rails. There is some paint overlap on the brick where the rails connect with the building. What is the most effective way to remove the paint?
Thanks!
Roger
Thanks!
Roger
I'd start with a stiff scrub brush and some comet. Or you could try a pressure washer- just be careful not to blow the brick and the mortar apart. If it won't come off, you can dissolve it with some paint stripper- but keep it confined to a small area so you don't make a mess of the whole wall.
Not sure, but my first thought was using a Jel paint remover and a brass or stiff nylon (plastic) brush. I am not sure if the paint remover will harm the stone/brick but I would doubt that it would.. Not sure I'd use a pressure washer inside a house but sure it would do the job IF the paint was loose....
