This is my first post to the forum. I dropped the remote for my PSI Lone Ranger II dust collector switch and needless to say, it cracked the circuit board inside(beyond repair). I checked my tool catalogs and on line and all the have for a replacement is a remote for the Lone Ranger III, not II. Before I call PSI and find out if the III will work with my number II receiver I was wondering if anyone has any experience with another brand of remote switch, if I am going to change now would be the time. My collector is 220 volts, and it is located in a separate room outside the shop.
I live in Russell Springs Ky, anybody nearby?
I live in Georgetown, KY just outside Lexington. Have you checked out the Oneida?
Ken
Thanks Ken, I checked out the Oneida switch this morning on their web. It's only about $10 more than the PSI Lone Ranger. I'm going to check further. I retired from Michigan just outside Detroit and found it a little eaiser to locate woodworking tools within a closer proximity. I found that I have to travel a little further because of living here near the lake, but you couldn't get me to move with a crowbar. Next time I head your way I'll drop you a message.
Thanks Again
Pops
I'm still here in Warren plugging away. Instead of a remote, have you considered a motor relay/contactor with hard wired switches. No need to carry the remote.
I used to live in Shelby Township, 23 mile and Van Dyke area, I sure don"t miss the cold and TRAFFIC !
I thought of the idea of hard wiring switches to late in the game, didn"t think of it until the shop was insulated and drywall was in place. If I would have hardwired switches I wouldn"t have the problem of always knocking the remote off my waist.
Pops
Look forward to it.
Pops, fix that circuit board. Use a magnifying glass to locate the break and scratch gently at both sides of the crack and using a small soldering iron, quickly solder a small dab of solder across the break.
After you've got it to work, use epoxy cement to reinforce the crack Don't use J-B Weld as it contains metal filings. Stein.
I did fix my circuit board this morning, my wife said I just needed to calm down after I did it. I used my continuity tester and found three broken circuit board lines. Ended up using superglue for the board crack and I had some adhesive metal tape(from my son's slot car days) which I placed on the broken contact points, cutting off the excess, got lucky it works fine now.
Pops
Nice to hear soneone took my advice. I made my first continuity checker in 1946 It was just an ear plug from an army surplus pilots head set with two probes in series with a penlite battery The thing used a piece of baling wire to hang it over my ear. Even used it later while in the signal corps to test phone wires and switchboards etc. Good luck Pops, Ed.
I have a Panasonic tv with a broken circuit board in the antenna port circuitry which drives me nutty. To get at the damn thing is a real Federal case. So, periodically, I have to twist the %$#@%$^ lead- in cable to get on with my History Channel. Still don't know who won WW II Ed.
Edited 2/21/2004 8:15:37 PM ET by steinmetz
Call the nice folks at PSI, they are very helpful and understand your problem.
Nearly impossible to repair for the cost of a replacement.
They went way out of their way to help me with a similar problem.
Curt
I did contact PSI and talked to one of their techs about repairing the remote, he said try to repair the board and if I didn"t have any luck give him a call back and we would go from there.
Pops
