Does anyone know if the correct term for the light spots in some quarter sawn red oak is “radial flecks”? I find this figure most often on the side of 8/4 oak.
Does anyone know of a source for a small quantity of this form of red oak?
David Smith
Pagosa Springs, CO
I am not an expert in this field,however I think that the grain pattern to which you refer,occurs most often on the faces of quarter sawn boards.Thank you,Mr.Croney,where ever you may be.
Work safely ¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬
Edited 10/14/2004 11:39 pm ET by Pat
Here are a couple of snippets from Hoadley's book "Understanding Wood."
White oak is actually the one that I most associate with striking ray flecks.
If you're sorting through some lumber looking for this figure, keep in mind (Hoadley again): "To reduce the size of ray flecks and yet produce an interesting pattern, woods such as lacewood and oak are sometimes cut just off the true radial...." (rift-cut or rift-sawn) I have frequently found nicely figured oak (white) in the "plain sawn" pile because the sorters didn't look for this rift-sawn lumber. I get it up to the counter, and the clerk says "Wow, that's quartersawn!" I just smile and write the check at the plain-sawn rate.
They are known as medullary rays, unique to the oak family.
"...medullary rays, unique to the oak family." Nope, sorry. This thread has prompted me to do a bit of reading, and here's what I've found. Medullary rays are tube-like structures that run radially within the trees. Present in all trees, but too small to be seen in most. Larger medullary rays are present in oak, ash, lacewood, American sycamore and maybe others I haven't found yet. White oak's "flake" is the figure that most commonly comes to mind.
forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
when I say oak family, I mean just that; oak,ash,chestnut,lacewood etc. They are not present in other woods.
Jack, medullary rays are indeed found in all trees.
None of the trees you named, ash, chestnut, lacewood, etc, are of the Fagaceae family to which the oaks (Quercus species) belong. Slainte.RJFurniture
I stand corrected; I was taught that medullary rays(from parenchyma cell patterns) were unique to oak and similar species. After reading more on this, I see they're present even in eucalyptus and many other trees. Thanks to FG and Sgian for pointing that out.
Edited 10/18/2004 10:02 am ET by JACKPLANE
David, to the second part of your question: obtaining some quartersawn oak. Any hardwood dealer should stock quartersawn white oak. What's your reason for specifying red oak?? How much and what dimensions do you need?
