question(s) about tung oil on padauk nightstand table top
Hi,
I’m finishing a nightstand I made of maple (cabinet/carcass) and padauk (table-top) with tung oil (pure, from Rockler) to match plans I saw in an old Wood magazine issue.
The maple seemed to accept the tung oil well and to my desired sheen (lost count on the number of coats, probably 8-10). I believe I have already applied between 8-10 coats on the padauk top as well. The regimine has been:
- apply the tung oil, let it set for 20-30 minutes
- then wipe up excess with a clean. dry rag
- let it cure for about a week
- sand/rub with 0000 steel wool (being careful not to rub too hard which would essentially remove the coat I just put down)
- repeat
I wonder now when enough is enough. Padauk has a somewhat open grain and the oil seems to soak in more in some areas than others. I’m think I am close to (or have surpassed the point of) the final coat, but how do I know, and what should my final steps be? Wax? Rottenstone? Buff out with felt pad?
Thanks in advance for reading and offering your advice, it is appreciated.
MikeB
For a nightstand that will receive a lot of wear, up to and including wet glasses perhaps, i think you need a film finish for ample protection. Wax certainly won't do it. 6-8 applications of a non-poly varnish wiped on (diluted 50/50).
You seem like a patient chap who is more than comfortable with hand application of finishes. Why not use shellac?
Shellac is beautiful, and it is actually more durable (wet stuff, etc) than many give it credit for, I'd do a varnish or more durable finish. Just another thought. ;o)
