Does anyone know of a place I could look online to find information about what combinations of pulley sizes (on the motor and a machine’s arbor) will give what rpm?
My new (old) bandsaw says 700 rpm, but it has no arbor pulley. (I haven’t measured the moror pulley yet.) I need to know what size pulley to put on the machine.
Any suggestions?
Alex
-Groucho Marx
The Old Woodworking Machines forum has several online calculators, including a pulley size/RPM calculator.Here's the link-http://www.owwm.com/math/default.aspx.
Rick W
VD = vd if memory serves me correctly. You will have to do the math. Velocity in rpm's times large pully diameter = velocity in rpm's times small pully diameter. No need for any books or graphs/charts.
In your case the big D will be the unknown, the big V will the 700 RPM, little v will be motor speed, little d will be motor pully diameter.
Good grief, It's been 35+ years since I took the exam for my Engineers license, and now I loose my glasses all the time ;-)
Bruce S.
Edited 5/4/2008 10:43 pm ET by BruceS
Edited 5/4/2008 10:44 pm ET by BruceS
Edited 5/4/2008 10:49 pm ET by BruceS
http://www.csgnetwork.com/pulleybeltcalc.html
Thats a slick calculator. Way back when! I had to push a pencil.Work Safe, Count to 10 when your done for the day !!
Bruce S.
I know your pain. My bandsaw manual was confused, the mfrs. rep could not help me. Out came the calipers and my pencil.
A nice collection of calculators
This site also can supply info on a nice range of old machinery.
Don
The ratios of the diameters of the pulleys are proportional, in other words a two inch pulley will drive a four inch pulley at half it's (the two inch) speed or vice versa.
A ten inch pulley has twice the circumference of a five, etc.
What you are concerned with is the ratio of the circumferences of the pulleys.
Since the equation fro circumference is Pi X d, for both pulleys, the Pi drops out, and all you need is the ratio of the pulley diameters.
If the motor turns at 3450-rpm, then to get 700 rpm on the wheel, the drive pulleys need a ratio of 3450/700. Which is 4.929, or roughly 5. So, the pulley on the motor needs to be 1/5 the diameter of the one on the wheel.
For a 1725-rpm motor, the ratio would be 1725/700, or 2.46. Which is roughly 2.5, so the motor pulley needs to be 0.4 the diameter of the one on the wheel.
Thank you all for the help. The calculators were quite helpful, and with the various explanations that people gave I was actually able to understand what was going on! ;-)
I remember something like this from my bicycling days many years ago. X number of teeth on the front chainring combined with X number of teeth on the freewheel was the equivalent of pedaling a direct drive wheel of Y diameter.... something like that.
I figured the machinery equivalent to this couldn't be all too difficult.
Thanks again,
Alex
-Groucho Marx
Alex,Don't forget that your target blade speed is expressed in surface feet per minute.
This is dictated by the blade manufacturer along with tension.This link provides some useful information, also a good source for bladeshttp://www.woodworkershaven.com/timber_importan.htmlDon
