Hello Folks,
I built three living room tables out of red oak and walnut. The final coat of finish will be sprayed waterborne lacquer. However, to give the wood a warmer appearance I applied a coat of Minwax “Natural” oil stain (number 209), which does not contain any pigments as far as I can tell. After applying the “stain” I noticed tearout in a few places in the three tops (black walnut) so I proceeded to fix that with a cabinet scraper followed by 180 grit sandpaper. I reapplied the stain to the affected area but now I get a somewhat different sheen between the repaired areas and their surrounding. The repaired areas seemed to not get saturated with the stain, which leaves them a little more bland. I re-applied a second coat and the problem persists.
Perhaps this sheen problem will disappear when I apply the shellac seal coat + lacquer final coats but I’d like to get a second opinion before I do that. The other alternative I see is to re-sand everything, which would not be such a big deal.
Thanks.
Putting on a sealer coat won't fix it. Your only using the cabinet scraper in the area to be repaired led differences in the wood's ability to absorb stain. Since the repair area is absorbing less stain, the scraper most likely burnished the wood. Careful sanding of the entire area (sanding equally everywhere) should fix it just fine.
good luck, JH
http://www.ithacawoodworker.com
JH said: "Careful sanding of the entire area (sanding equally everywhere) should fix it just fine."That's what I ended up doing. The tops now look fine with a new coat of stain.Thanks
