Hello All!!! I would like to get some idea what the market would allow price wise for a ” FEDERAL CARD TABLE ” Re: FWW #180 pp 54-63. I am just about complete, and I have no idea what I could get for it. I have sunk over $ 600.00 in it including special tools, hardware and inlay materials. This does not include lumber or labor. I really don’t how many hrs. I have on this.
Any idea’s
Thanks Jack
Fine Woodworking Recommended Products
Grizzly G0495X Industrial Helical Cutterhead 8-in. Jointer
Regardless of the board’s grain, this jointer produced excellent results. Its fence was totally flat, worked smoothly, and locked well, staying in place even after jointing multiple edges. Getting the fence to 90° was very easy, but the 90° stop was a little tricky to set and the fence did not go back to square when using it. For those who would use it, there is also a digital depth-of-cut scale.
Preppin' Weapon
The Preppin' Weapon allows you to use a 1/4 of a sheet of sandpaper, incredibly comfortable to use, and you can switch out sandpaper easily.
iGaging AccuMarking Digital Wheel Marking Gauge
A digital readout on the AccuMarking gauge measures to the nearest 0.0005 in. It can also be set to fractions or millimeters. Lacking a micro-adjust, however, it took a steady hand to dial in exact dimensions on the sensitive readout. The cutting disk needed considerable work to correct a rounded-over edge, but once sharpened, it cut well.
Ridgid R86044B
Power: Good Cut visibility: Very good Control: Good (with standard base) Bit changes: Good Depth adjustment: Excellent
Makita 9903 Belt Sander
Weight: 9.5 lb. Amps: 8.8 Variable speed: Yes Belt alignment: Excellent Material removal rate: Very good Sanding flatness: Excellent Shaping/scribing: Very good Handling on side: Fair Dust collection with hose: Fair
Jack
A picture is worth a thousand words, and even more money. It's impossible to arbitrarily value a piece of furniture especially a period reproduction, based on a drawing. If your execution, joinery, and finish are spot on, then the final price of the piece will reflect that. I have made pieces I've sold for $3000.00, and I have made pieces I've sold for $15,000.00.
Show us!
Edited 3/22/2008 4:22 pm ET by JeffHeath
Hello JeffHeath !! Like I said I am still working on it, when I have finished the project I will sure as h*ll get back to you.
Jack
Jack,
As a general rule, for simpler projects, I multiply the cost of materials by three to get and estimate for the final price. However, the table isn't simple with delicate inlays, curves, and such. Also you have invested some serious change in special tools. Figure out how much the tools you bought will be used once the project is done and factor that into the cost.
Now, bear in mind that what you should charge is much different from what you could get. It depends on how you price it and who your market is. If you ask top dollar for your work, you'll limit your market but also empasize the quality of your work. If you price it low, you'll probably sell it quicker but one might question why it's so cheap and suspect quality. Food for thought.
Chris @ flairwoodworks
Just make sure you don't count the cost of tools in your calculations.
These are overhead, not direct costs - even if you bought it just for this project.
You still have to be paid for the overhead. The depreciation on all your tools is a part of the costs, and special tools that are unlikely to find another use in the clearly foreseeable future should be completely depreciated immediately.
However, costs are only one part of the equation. Knowing your costs, including paying yourself a wage, tells you the minimum price you would sell the product for, not the actual sales price. The idea is to make a profit, in addition to the wage and the expenses.
Apparently the table was built on speculation. If you can't find the buyer you may end up taking a loss. You should be compensated for that risk. Strangely, sometimes an item will find a buyer faster at $6,000 than at $3,000.
