I am making a built in cabinet unit in our kitchen and would like to use pre-made oak tambour for a sliding curved corner door. Instead of the tambour moving up and down as in a roll top desk, this would move around a corner side to side. I will have to purchase a pre-made canvas-backed unit from Rockler and cut it down from 50″ to about 30″. I don’t know why it wouldn’t work. I would just use a router to make a channel for the unit to move in. Anyone have thoughts on this project?
If I understand you correctly I don't think this is going to work the way you want it to. The stress/friction is all going to be on the bottom of the tambour dorr. Its sort of like trying to make a window shade work sideways with the bottom edge running along the sill. At least I think I would cut the tambour door into two separate pieces that met in the center. Like a right and left tambour door that meet in the center of the corner. Never tried it though, maybe your way would work.
Thanks for your input. That is a good point.
I stand corrected. Please let us know how it turns out.
I've seen horizontal tambour in factory-made furniture or maybe cupboards, but I don't know how they dealt with the stresses mentioned above.
Horizontal tambours are perfectly feasible, though a store-bought one might be on the flimsy side. The setup is a bit more complicated than routing a groove at the bottom -- even the groove has to be widened at the corners to prevent sticking. There's quite a good discussion of the various ways to do it in Joyce's Encyclopedia of Furniture Making, p. 260 of the revised edition. The writing's a bit old-fashioned, but the information might save you some grief.
Jim
JJ .
I have made pieces with vertical tambours exactly the way you want .
You make a top and a bottom track the same usually you can make the tambour removable from inside . These two tracks need to be accurately the same .
Making the track with a router and template fitted with the correct bit and template guide bushings is one way .
Rub some paraffin wax in the track grooves after it is finished and the tambour will glide effortlessly .
You can make a lead strip on each half fashioned like handle . You fit the two leading edges to suit .
regards dusty
JJ
Amana Tool makes a tambour router bit kit that will make a tambour door any size you want. The slats fit together and there is no canvas. Tom
i noticed that router bit but have no idea how it would work. I will definately consider that idea further.
jim
John and Thomas Seymour used horizontal tambours in their cabinets 200 years ago. Some of their single tambours span as much as 21".
Dick
