Forgive a non-wood topic. I have a 5″ random orbital sander that takes hook-and-loop paper. Do they make buffing disks that I can use to buff a car? It’d be nice to reuse my woodworking tools rather than buy something new.
i've seen buffing disks before. maybe an auto supply store would be a good place to look.
*I purchased a Bosch velcro-backed buffing pad for my 5" R.O. but wasn't really impressed; the orbital effect seemed to make the pad less effective than a true polisher. Cost about $20.00
*I have the Rupes ROS (and their orbital sander) and both of these are sold primarily to the car body repair trade so I don't see why the ROS couldn't be used for buffing as well. Mine is a peel-and-stick model.
*Just don't do what a friend of mine's uncle did, chucked a buffer into his router and tried to polish his car up. Whoooopeeee!
*Don, it will work if you only intend to do a small area and you are very careful to not let it spin or rock. Normally professional buffers have a much larger, thicker and flexible pad design. This helps the user to not burn the paint which you will do if it spins at a high speed or rocks. While ROS's are sold for auto body repair the are not intended to be buffers. Rather, they are designed for smoothing of fillers and pre-final sanding work.If you are still going to try it, test and get the feel for it before you use it on any large surface.Steve
*Thanks for all the tips. I'm going to go slow and see what happens. Luckily its my son's car :-)- Don
*I don't see why not as long a the polishing pad is thick/soft enough. On the other hand an RO car polisher (aka Waxmaster) does an nice job on buffing furniture and can't burn the paint.
