Merry Christmas and Happy New Year.
I have two questions. I’ve been asked to refinish a kitchen table top that a few years ago I applied several coats of polyurethane to. Can I just sand it first to rough up the surface and put another coat of polyurethane on top? Or, should apply a coat of shellac first? or what?
My second question is, where can I buy a good quality natural bristle brushes?
Thank you for any and all suggestions and advice
Sand the surface well with 220 paper. You'll want to give the surface good tooth for the next coat. I would also follow with a good rubbing with a maroon scotch pad.
Clean the surface well to remove all the dust. As a final prep, dampen a cloth or paper towel with mineral spirits and wipe the surface and dry it as you go.
Apply the poly in thin coats, you will get a much better job than if you pile on a couple of thick coats.
Check out toolsforwoodworking.com for brushes, also Kremer Pigments in New York. Sorry I don't have a link for you.
Good luck.
Peter
Mr. Gedry,
Thank you for your suggestions on how to refinish my table which I will follow to the letter. Also, for the brush sources.
Again, thank you, Merry Christmas and Happy New Year.
Chris
