I just finished using micro mesh to sand my shellac finished banjo rim. I went through all the grits up to 12,000. I think there’s just a little more gloss to be had. Any thoughts on how to get more gloss? It’s very shiny now; for lack of better terms, I’m looking to go from gloss to GLARE.
Shiny
For the last shellac finish I rubbed out, I used wet/dry sandpaper and finished with 0000 steel wool lubricated with wax. Then I buffed out the wax. I would say that the finish is glossy... how glossy compared to yours I don't know. You might also try an automotive polish - many pen turners use that stuff.
Auto polish is the way to go. I recently bult a walnut case for a vintage stereo receiver. It was finished with several coats of clear shellac. Between each coat, I buffed using 0000 steel wool. After the final coat, I again buffed but used a bit of slightly soapy water in conjunction with the steel wool. After it was totally dry, I used auto polish and came away with a finish that still looks wet these many months later.
Cheers,
Ed
Auto polishing compound is your route. From very glossy to more, I'd go with products called something like swirl remover.
For next time, you might consider a French polish process. Great depth of gloss with almost no apparent thickness.
Thanks for the guidance. I
Thanks for the guidnace. I used a product I already had called "Show Car Glaze". Man, you talk about gloss!
