It’s me–the newbie again.
I’m building a simple piece for my shop out of CDX plywood, which is just under 3/4″ thick. I want to use dados for some of the joints, but my 3/4″ router bit will cut the dado just a hair too big, leaving me with a sloppy joint.
I’ve read that there are special router bits for undersized plywood. I don’t want to spend much money on these bits. Any suggestions? I know 3/4″ plywood thicknesses can vary quite a bit.
There are couple of ways to deal with this problem. The first is fairly obvious, shim the dado slot. Since most ply vary in thickness, I would suggest that you under cut the dado slot using a 5/8" dado bit and then rabbet the plywood to match the slot.
Doug
A second suggestion requires a deft touch. Reverse the polarity on your router, then mount in a table. With the machine on, apply a honing stone to remove a fraction of material until with dial calipers the bit diameter is correct. Use eye and respiratory protection.
Couple of options here ,
Just pick up a cheap set of bits from woodline (great bits, cheap but good) or
buy one 3/8 to 1/2 bit from woodline and cut then move the fence and cut again...
But
personally, id spend the 20 bucks on a set from woodline Buck Construction View Image
Artistry in Carpentry
Pgh, PA
I have been wondering about how to route dados for plywood that may vary in thinkness. I was thinking of building one of those adjustable parallelogram jigs that can be set at any width, then clamped to the board and serve as a fence for the router. I had a basic question though. When setting up fences for routing slots, is it better to guide on the router baseplate, a collar around the bit, or use a bit that has a roller bearing to guide it?
I never cut a full size dado to fit a piece of ply -- for all the reasons mentioned above. I generally cut a dado at 1/4" -- either with a TS dado or a router -- and then rabbet the ply to fit.For routering, to keep things quick and easy, I use one of those flat, guide clamps. To measure the distance from the guide clamp to the router cut, I have made up two different boards (one for a 1/4" cut, the other for a 1/2", both made from 1/4" luan ply). All I have to do is mark where I want the edge of the router cut to be, lay down my jig board, square it up, slide the guide clamp up to it, and tighten it down. I also have made up some shooting boards which I occasionally use for router cuts."I would never die for my beliefs because I might be wrong."
-- Bertrand Russell
Nice technique.
The Other Ez way is the smart router kit. Instead reposition the "shooting board"
The sliding arm moves in and out. As long as you position the "shooting board" parallel to your desire dado or whatever, the rest is under control.
Edited 4/18/2005 9:27 pm ET by YCFriend
Edited 4/18/2005 9:28 pm ET by YCFriend
I think a link should be provided:
http://www.eurekazone.com/products/ezsmartrouter.html
Eurekazone, Inc.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
It's possible that you have 17mm thick plywood rather than 3/4. It seems to be the norm today. I your going to a lot of dadoes in plywood then it might be worth investing in the 17mm bit.
Otherwise you can make a jig using a bushing and a 1/2 or 5/8 diameter bit. Rip a couple of 4 to 6 inch strips of plywood (or MDF). Attach a another strip to the end of one at a right angle. I like to use that piece to square it against the stock. Pick your bushing/collar size. (Say 3/4 diameter for a 1/2 diameter bit) Run the router into the cross piece. That will be your one edge. Mark your thickness on the cross piece and account for the difference between the bushing and bit. Mount the other strip to the cross piece and another cross piece at the other end. Voila.
Hope this helps.
Toolfreak,
One other option: use a 1/2" router bit for the dado and put a 1/4" rabbit on the underside of you ply shelf..adds strength too and puts you back in control.
I've used the special sized 3/4" bit and have found the thickness of the ply to vary.
Edited 4/18/2005 10:56 am ET by BG
Maybe an adjustable dado blade for your t/s?
Toolfreak,
I spent this last weekend cutting dados and rabbets for kitchen cabinets for my kids on the table saw with a dado blade. Had to do a lot of test cuts to get the right width with shims but everything worked out well.
ASK
Build this jig from Shopnotes:
They even have an online video showing it in action. I built it and it is sweet. The guides self-align for the thickness you're actually using. So it doesn't matter how thick or thin the material is.
Joe
Joe,
What issue was the jig in?
Doug
Just go here:
http://www.shopnotes.com/main/sn76-toc.html
Joe
Joe,
Thanks. That issue is not listed in their back issue availability but I emailed them to inquire further.
Doug
Email me :
Jscharle@nc.rr.com
Joe
For those who want to search their own library, that router dado jig is in #76, July/August 2004.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Thanks Jamie. I don't take ShopNotes but I'm trying to purchase a back edition.
Doug
Any time, Doug. If I had a copy, I'd try and help you out, but last summer I let my subscription lapse. Wish I hadn't, I could use that jig. I'm there are other designs out there, but this one sounds like a good one!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Several years ago, I bought two straight cutting router bits for "undersized" plywood. One is 23/32" and the other is 15/32". If memory serves, I got them from MLCS (http://www.mlcswoodowrking.com).
I got a set of three "plywood size" router bits at Rockler. I had one of their discount cards, and was loading up on goodies that day.
-- J.S.
http://www.grizzly.com/products/item.cfm?itemnumber=H5558
Heres a plywood set of bits from grizzly $12.95
