I’m looking to build some spiral library steps. I seem to have trouble finding any info on these. I have 10′ ceiling and I think the post needs to be about 6-7′ in height. On the steps I’m not sure of the rise or length. Hope someone can lead me in the right direction or if there are any plans .
Dear Mags0722,
Unfortunately, we don't have any library stair plans on our site. There are a ton of stair articles on our sister site, FineHomebuilding.com (see sampling below) if you wanted to get some general info about rise and tread dimensions. If you see an article of interest, I can try to pull some strings and get you a free pdf.
Our books department also just published a book on stairs that whould have the latest information on stair codes.
Good luck with your project,
Gina
FineWoodworking.com
Stairways can be minimal or very elaborate, but they're all based on simple geometry and accurate finish work ...
by Bob Syvanen
Using plywood instead of framing lumber can guarantee a stable and accurate staircase that won't break the bank ...
by Alan Ferguson
Whether it's four steps or four flights, the framing basics for safe, comfortable stairs are the same ...
by John Spier
About manufactured stair parts, and how they are made ...
by Kevin Ireton
Getting the details right might save a life ...
by Gregory Harrison
With a housed stringer on one side and an open, mitered stringer on the other, these stairs look harder to build than they are ...
by Andy Engel
A stick-framed stair lifts the eye upward while keeping the costs under control ...
by Russell O. Bessonette
Using stock lumber and common shop tools to build an elegant circular staircase ...
by Steven M. White
Laying the handrail on the stairs is the first step ...
by Sebastian Eggert
Basic construction techniques for a stair with a three-step winder ...
by Larry Haun
A stud wall, not a laminated stringer, shapes these stairs ...
by Scott Paschal
Fitting stairs to a complicated site called for an accurate sketch and some job-site improvising ...
by Thor Matteson
Folding stairs are the most common, but sliding stairs are easier to climb ...
by William T. Cox
Using readily available materials and on-site carpentry techniques to build a tasteful staircase ...
by Alexander Brennen
An arts and crafts stair becomes the focal point of a house searching for a style ...
by Miles Karpilow
A temporary form and laminated plywood stringers make building these stairs easier than you might think ...
by Mike Guertin
Before settling on a costly addition, make the most of the opportunities under your existing roof ...
by Keyan Mizani
A cherry spiral built with divine inspiration, a little steam and a lot of clamps ...
by Robin Ferguson
An adjustable mortising jig simplifies the construction of an open-riser stairway ...
by Bill Young
