My Dewalt planer will soon need new blades, I am wondering what you guys in the U S of A pay for them. Up here in Canada 3 replacement blades for the DeWalt 734 cost $ 69.99 plus 15% tax. or $ 81.00. Its Highway robbery.
Is their any other blades that would fit, Tell me what in the %&^*&^ are they made to account for the high price they charge.
I love the planer, but I would love it even more if the blades were much cheaper.
Jack
Hi Jack,
(Wow! I don't want to greet you in an airport, do I? ... Sorry. Old joke.)
I have the Dewalt 733. Its blades can be resharpened and I have a friend who's shop includes a surface grinder. He charges me 10 or 15 bucks (U.S.) and even made a fixture to simply his work. - BUT, I don't know if the blades of the 735 can be resharpened. I wish I could offer more help.
Btw, they get $50 U.S. for the two-blade set for the 734. For some reason, the dealer (Woodworker's Warehouse - now defunct) gave me an extra (third!) set when I bought the planer. Maybe he liked me...?)
Pete
Pete Thanks for a quick reply, but my 734 has 3 blades.
Jack
Oh nuts, Jack!
Thanks for correcting me. I must be overtired. MY planer is a 733, not a 734, and your is not a 735, it is a 734 as you say. I am allll conphoosed ... but my blades are re-sharpenable and I don't know if yours are or not - and it sounds as though they aren't.
Good luck in your search. Have you checked in with Freud? (The tool maker, not the shrink.)
Your stoopid friend (who actually is quite tired tonight),
Pete
PeteToo,
I cracked a blade on my 735 not long ago and the bracket that holds it in place. While at the Porter Cable, B&D and Dewalt repair centers the technicians swore that you could resharpen the 735 blades although the manual says you can't. Honestly I don't see why you can't if there is metal there. Anyone have any insight on this?
Hi Bio,
(Thanks for your inputs to the dust/toxicity questions too!)
The 733 has two little magnetic "jig"-like devices, in combination with a spring behind the blade, that register (hold) the cutting edge of the blade at the correct extension before it is clamped down by the mounting bolts. It's clever and it works.
IF the 735 has a similar "cutting edge-registering" system then I see no reason why the blades can't be resharpened *but I don't know what it has*.
Presumably, if one removes exactly the same amount of metal (and not very much - as in honing as mentioned above) from each blade in the sharpening process, this wouldn't matter - but you can't easily be sure of that.
Still, since I don't know how the 735 blades are mounted/registered, I feel as though I'm speaking when I shouldn't.
Pete
The 735's mounting system couldn't be more straightforward - you drop the blades onto 3 posts in the cutterhead. The precision I was referring to is the blade width and the location and height of the mounting holes - they're incredibly precise. I measured them with an engineer's digital caliper and I found that all 9 on my set of blades was within about 1/2 of a thousandth of an inch from the cutting edge of the blade.
In fact, measuring the distance from the blade to the near side of the mounting holes is a pretty good way to figure out if your honing has been consistent across the 3 blades. So long as the distance is consistent amongst the 9 nine holes, you can be pretty sure that the freshly honed set will work as if they were new.
Yeah I don't know if you can sharpen them hundreds of times but I'm sure you could touch them up a few times and have no problems. What is interesting to me is what makes a blade disposable? Out of the DeWalt shop why did they decide all of a sudden these couldn't be resharpened like many of their other blades?
"What is interesting to me is what makes a blade disposable?"
Basically, it's a crossover in the cost curve. When the cost to manufacture a disposable blade falls below a certain point, then buying a new disposable blade is cheaper than having a conventional blade resharpened. Obviously, the process of reducing the manufacturing cost takes into account the knowledge that the blade isn't intended to be resharpened, meaning that it can be made with less "meat."
>>" Obviously, the process of reducing the manufacturing cost takes into account the knowledge that the blade isn't intended to be resharpened, meaning that it can be made with less "meat." "<<
Welllll, in principle maybe.
I just measured one of the blades from my 733. It is 0.125" (1/8th) thick and 1.044" from heel to edge (and 1 inch and 19/32 across (wide), of course) but my point is its thickness. Even a blade made to be replaced rather than re-sharpened *should* have some beef to it, just as the higher quality hand planes have thicker blades than cheaper ones.
MY question, Steve, would be: Why did they drop the neat indexing system (with the magnetic "jigs") of the 733? I am asuming that any *decent* planer blade has to be at least as thick (as beefy) as those of my 733. Maybe that's an incorrect asumption.
I really wish I could get a close look at a 735 - meaning closer than I can get in a store - to see their blade mounting system and judge for myself the sharpenability of the blades.
I certainly agree with DKeller that one can and should be able to extend the life of a set of blades with his honing technique, and his counting of honing strokes per blade is an admirable method of keeping things consistent.
How about getting sneaky: Sharpening the blades and then putting thin shim stock between them and the back-up posts to compensate for the material removed by sharpening?
(Or is this getting a little too wild?)
Resectfully,
Pete
I can snap you some pictures real quick if you would like.
I'd love to see them - but realize please that my interest is strictly academic. I am long retired, on a semi (mostly) fixed income and I don't plan to part with my DW733.
*smile*
Ackshully, what we all would probably like to see is a really good way for our Canadian friend to save money - already at least partly provided my DKeller's suggestion.
Pete
What academics are you addressing? I don't know if the mounting mechanism will tell you much.
Academic in the sense of adding to general knowledge but qualified, as I said, that the knowledge would probably be without practical purpose. It might however be helpful in some way to others here.
I'm just going to keep re-sharpening my three sets of 733 blades as they need it. I just bought about 100bf of nice, air-dried, roughsawn cherry, fer instance, with more to come. And I still have some BIG slabs of walnut from a tree my Dad and I cut down fifty years ago. (I was a late starter in this woodworking thing....)
Pete
Ha, sell me 20bdft of that Cherry. You don't need all of it :)
More important than the thickness of the blade itself is how well it is supported in the cutterhead.
Absolutely no argument there, Steve, (not that I'm arguing at all - I'm not) and it may be that the 735's cutter head is itself beefier than that of the 733, allowing "cheaper" blades.
(*sigh* .... I'll bet thre's a Harvard MBA among the bean counters.)
As an interesting aside, when I first delivered two sets of 733 blades (I have three) to my machinist friend for sharpening, he called me with a question:
"Do you want the bevel at 37 1/2 degrees or 40 degrees?" he asked me. It turned out that one pair were beveled (by Dewalt) at 37 1/2 degrees and one set was at 40 degrees. I decided on 40 knowing that the steeper angle would cut well but dull sooner - but with three blade sets and a helpful friend, why not?
Pete
Pete - Shimming the blades on the 735 wouldn't work (and wouldn't be necessary). The blades are held by fitting over 3 posts in each blade location - naturally, there are 3 holes in the disposable blades. It's those holes that provide the correct cutterhead alignment - they are very precisley located in the center of the blade. The slop in those holes is all in the direction paralell with the length of the blade, which allows you to shift a knife that's gotten a chip in it.
Ahhhh HAH! Thank you. NOW we know how they did the dirty (so to speak).
My 733 blades are sprung out to and register against temporarily placed magnetic "jigs", as I've mentioned, and are held firmly in place by eight 1/4" capscrews.
Although I still haven't seen the complete layout of the 735 blade mounting I know that using springs for position and holding each blade in place with eight capscrews (into eight drilled and tapped holes - sixteen per cutterhead) is most likely quite a bit more expensive to manufacture than using a stud-indexing system such as you are describing.
I can't help but to say Nuts to the "no-shim works here" arrangement. I guess they call this progress.
I wonder if anyone knows how much sharpening can be done to 735 blades before there is not enough blade left to work properly.
(The two-feed-speed 735 came out only a few months after I bought my 733. For a while I lamented this fact. No more now because I am very happy with the 733 and the fact that my friend charges only ten bucks per set to sharpen the blades - and these blades are beefy enough to last for years and years.)
Pete
Oh by far the 2 speeds isn't the best feature of the 735. The blower on that thing is NICE. I simply have my 735 hooked to a 55 gallon trash can and it works like a charm. Does your 733 have that feature?
Nope. No blower, darn it.
In fact the dust collection "hood" that came with my 733 was supposed to be an option, I think. I have that hooked through a 4" to 2" adapter to my Fein Turbo III (Model 9.77.25).
The Turbo III serves as my primary dust collection device - moved from machine to machine - in my modest, *little* hobbiest's shop. I am however, since seeing it mentioned here in Knots, seriously considering adding a version of the Dust Deputy.
A 16 gallon Sears "5.5hp" shop vac was relegated to rare back-up use due to its incredibly noisy nature. In fact I usually use it only to clean the Fein's felt filter - or to suck up the dead leaves out of the cellar staircase.
Pete
Speaking of the 735, I had a project that was due and I ran some 4/4 Walnut through the machine and it caught on a knot. I heard this huge bang and the breaker blew just prior to this very loud sound that is hard to describe. All around my shop were pieces of the blade and the housing unit. Apparently when I flipped the blades over to be used I forgot to put one screw back into the bracket that holds them in. This one missing screw caused the bracket to bend and was literally ripped apart by the high rpms produced by the unit. The rest lets just say was a scary mess. See the attached.
Yow! Reminds me to very carefully tighten those screws the next time I take the blades out.
As to how many times you can hone them, I'm not sure, but the set I have in the planer now have been honed 3 times. Since they're reversible, I figure I got my money's worth with 6 fresh edges and it's probably time to buy a new set.
For a lot of woodworkers, being able to use the blades for 6 times until they dull would last a number of years.
The only thing I don't like about this system is the potential for obsolesence. I re-tuned my grandfather's 15" planer from the 1960's for my father, and blades were readily available, perhaps because they're just pieces of thicknessed tool steel with an edge on them.
I wonder the same thing about replacement carbide-insert jointer cutters. The upgrade is pricey, and it'd really stink to do that to my DJ-20 and then not be able to get the inserts in a few years.
The reason they're that expensive is that they're made of high-speed steel and manufactured to very close tolerances - those close tolerances, ironically, are what make them "disposable". If you choose, and your blades are not too badly nicked, you can hone them yourself. I do so, and it doesn't seem to negatively affect the performance in any meaningful way.
My procedure is to flatten the backs carefully on 400 grit wet/dry sandpaper glued to a jointer bed. It's important to use the same number of strokes on each blade (clean any resin off with kerosene or laquer thinner first!), so I count them out.
After polishing the backs, I mount the blade on a jig of MDF so that they can be held flat, horizontal and parallel with the benchtop's surface. I then use a DMT diamond stone hone (their "credit card" model) in the "fine" grit. Again, I use the same number of strokes on all blades so that I don't accidentally hone one narrower than the others. About 10 strokes is required to get them razor sharp. I don't worry about removing nicks, because doing so would alter the blade geometry enough to potentially cause performance issues - I just shift the knives in their mounting slots slightly so that knicks don't show up on the wood surface.
tpilt2v insurance
zk86oo8d
bg7ymzyo
insurance
x0u9s06r
ws2oucn4
fbd62lo insurance
kced7q22
uzpei7gk
insurance
jboyjixr
wlrfghe5
4swdhjs insurance
v5s60ld0
olkkoka0
insurance
g3chlwwy
l1375n3a
144dqxu insurance
ll36sl7p
yxbprobu
insurance
pgajrqot
tv4ivb92
144dqxu insurance
ll36sl7p
yxbprobu
insurance
pgajrqot
tv4ivb92
orbqkwf insurance
ek0qg6e0
nbea9yal
insurance
lcm0ncqo
ps7ty5qb
orbqkwf insurance
ek0qg6e0
nbea9yal
insurance
lcm0ncqo
ps7ty5qb
omfcgye insurance
s7n1q0u5
ynwi8xdh
insurance
faiyw8rn
n3i05u6e
omfcgye insurance
s7n1q0u5
ynwi8xdh
insurance
faiyw8rn
n3i05u6e
ot9ypkw insurance
ec8ccdmn
eat4w9hn
insurance
v4h7xa1t
nwx4i4v1
ot9ypkw insurance
ec8ccdmn
eat4w9hn
insurance
v4h7xa1t
nwx4i4v1
51zbyky insurance
l33wr0n6
lesjqtsx
insurance
p0fziotd
diswpawf
51zbyky insurance
l33wr0n6
lesjqtsx
insurance
p0fziotd
diswpawf
h556axj insurance
za0lsro8
majdvzfe
insurance
godsywap
ahzgpqk6
h556axj insurance
za0lsro8
majdvzfe
insurance
godsywap
ahzgpqk6
662ayv0 insurance
kbyr03b1
gomyuq9j
insurance
r06xa037
tlic9ybb
662ayv0 insurance
kbyr03b1
gomyuq9j
insurance
r06xa037
tlic9ybb
cmg2ah9 insurance
js6q9gfx
e7pgxjby
insurance
d5pd7l6b
ykmxkq7v
cmg2ah9 insurance
js6q9gfx
e7pgxjby
insurance
d5pd7l6b
ykmxkq7v
gdxrnvh insurance
eqoso7dk
i4tx339b
insurance
bdi496n3
lcba2csx
gdxrnvh insurance
eqoso7dk
i4tx339b
insurance
bdi496n3
lcba2csx
lbqolnq insurance
wjzcgpz5
fereuxrk
insurance
nv0awaou
ijbp2fhu
lbqolnq insurance
wjzcgpz5
fereuxrk
insurance
nv0awaou
ijbp2fhu
3s1l3wc insurance
bw6owhxm
q89zh6ax
insurance
crsl751u
omu0ptlv
3s1l3wc insurance
bw6owhxm
q89zh6ax
insurance
crsl751u
omu0ptlv
gga39iw insurance
db8up5dq
ewr9igxf
insurance
n6n5uxqe
d7jqsbpg
gga39iw insurance
db8up5dq
ewr9igxf
insurance
n6n5uxqe
d7jqsbpg
2uyzmzk insurance
hzy9se3v
spzk98fd
insurance
gj6spkeu
eks4v22x
2uyzmzk insurance
hzy9se3v
spzk98fd
insurance
gj6spkeu
eks4v22x
4enrhx3 insurance
v5d7mqgd
gmslyo1v
insurance
rfzlhvab
ru8rltux
4enrhx3 insurance
v5d7mqgd
gmslyo1v
insurance
rfzlhvab
ru8rltux
38vfvm5 insurance
os9nkg7m
ghr8czak
insurance
aasiirjn
jmxrlfs1
38vfvm5 insurance
os9nkg7m
ghr8czak
insurance
aasiirjn
jmxrlfs1
4o3icuc insurance
l63kmcgw
xbeukqf0
insurance
ykpiiguv
in2925b9
4o3icuc insurance
l63kmcgw
xbeukqf0
insurance
ykpiiguv
in2925b9
5aa786n insurance
htqzwl6w
p2fij5j8
insurance
ftoenlxz
elwwti1t
5aa786n insurance
htqzwl6w
p2fij5j8
insurance
ftoenlxz
elwwti1t
v7vfdko insurance
kbbyi529
v2j8ev85
insurance
u1qy7s2w
hctt2p9v
v7vfdko insurance
kbbyi529
v2j8ev85
insurance
u1qy7s2w
hctt2p9v
8f3mu8b insurance
lnh4pd23
bz9ujs6h
insurance
yyodhex9
m45p6ygc
8f3mu8b insurance
lnh4pd23
bz9ujs6h
insurance
yyodhex9
m45p6ygc
bkusey6 insurance
p7v1t0k6
h2tk1a9m
insurance
epik8hjk
w2znavvn
bkusey6 insurance
p7v1t0k6
h2tk1a9m
insurance
epik8hjk
w2znavvn
7qh6nld insurance
olfl7lgk
nimn2i46
insurance
vig9q1t0
kcsjz0ek
7qh6nld insurance
olfl7lgk
nimn2i46
insurance
vig9q1t0
kcsjz0ek
3c202fo insurance
c9lje0o7
o5rda4n5
insurance
ci2q958f
x8f5x9cc
3c202fo insurance
c9lje0o7
o5rda4n5
insurance
ci2q958f
x8f5x9cc
mbnwbzn insurance
q2zk4f6c
qvxfglo4
insurance
bz09kdsx
fsuqm5h8
mbnwbzn insurance
q2zk4f6c
qvxfglo4
insurance
bz09kdsx
fsuqm5h8
5p94byu insurance
vdntv2tq
z3mu58p6
insurance
ofxuipj4
r0qo230n
5p94byu insurance
vdntv2tq
z3mu58p6
insurance
ofxuipj4
r0qo230n
f6ruvwr insurance
tqaqv2r7
qv7yrmsn
insurance
nquqfh6w
me03vswz
f6ruvwr insurance
tqaqv2r7
qv7yrmsn
insurance
nquqfh6w
me03vswz
iw5yafi insurance
bvy86n9m
ql7zbqht
insurance
wfectcvx
ziq1itp3
iw5yafi insurance
bvy86n9m
ql7zbqht
insurance
wfectcvx
ziq1itp3
68sgcb0 insurance
uw8umu0e
j19d67eu
insurance
hv73dilo
pokbpo0s
68sgcb0 insurance
uw8umu0e
j19d67eu
insurance
hv73dilo
pokbpo0s
4dvzjrl insurance
ed8z80ua
tsqhrfwd
insurance
ybzscgcy
k4q7qufs
4dvzjrl insurance
ed8z80ua
tsqhrfwd
insurance
ybzscgcy
k4q7qufs
2v0nmfs insurance
lodfxqdt
uvlwvhpo
insurance
mgmomt7l
dbwjqi7u
2v0nmfs insurance
lodfxqdt
uvlwvhpo
insurance
mgmomt7l
dbwjqi7u
jtwayow insurance
zf1tzg3a
bth3f93i
insurance
vjtdqm4q
qwn3ruuc
jtwayow insurance
zf1tzg3a
bth3f93i
insurance
vjtdqm4q
qwn3ruuc
2fliwt0 insurance
ix0il9td
a62b1e8o
insurance
p4cx9hcs
cvb43hc1
2fliwt0 insurance
ix0il9td
a62b1e8o
insurance
p4cx9hcs
cvb43hc1
r0c692p insurance
atkmy48m
bz51sw4y
insurance
h63oj8wq
lwimoltf
r0c692p insurance
atkmy48m
bz51sw4y
insurance
h63oj8wq
lwimoltf
3j5gp27 insurance
oplz8y9s
wgq257e3
insurance
hqskfvvh
wda3f7ni
3j5gp27 insurance
oplz8y9s
wgq257e3
insurance
hqskfvvh
wda3f7ni
s3elcan insurance
fokx3mbj
mzbnfg5h
insurance
oykwfr6s
nmuxwm0h
s3elcan insurance
fokx3mbj
mzbnfg5h
insurance
oykwfr6s
nmuxwm0h
gsbshpw insurance
ta3chh1k
qtizizu6
insurance
zkzq30f9
t63nj0tt
gsbshpw insurance
ta3chh1k
qtizizu6
insurance
zkzq30f9
t63nj0tt
nxgwhan insurance
xl2e762y
su3ts7ew
insurance
u6v3ni3t
qbob5l97
nxgwhan insurance
xl2e762y
su3ts7ew
insurance
u6v3ni3t
qbob5l97
l51wtrm insurance
u8jt2ytj
abyoouvt
insurance
n0o4i4h9
ay2n0is8
l51wtrm insurance
u8jt2ytj
abyoouvt
insurance
n0o4i4h9
ay2n0is8
oq0ykme insurance
y6swrd6f
oqvvvi73
insurance
qstolbu0
zwyslzrd
oq0ykme insurance
y6swrd6f
oqvvvi73
insurance
qstolbu0
zwyslzrd
m504fcz insurance
uzcj1b4s
xagp8wi2
insurance
nq9r8m31
fv6k8rui
m504fcz insurance
uzcj1b4s
xagp8wi2
insurance
nq9r8m31
fv6k8rui
b9z72wa insurance
v24l05f5
dt3geafc
insurance
dziufz70
ppnl24er
b9z72wa insurance
v24l05f5
dt3geafc
insurance
dziufz70
ppnl24er
xab2aa1 insurance
v5xjesoe
qaa68jc0
insurance
acfpmjnm
d4ox1wdc
xab2aa1 insurance
v5xjesoe
qaa68jc0
insurance
acfpmjnm
d4ox1wdc
2t572gw insurance
gwtlymmv
u98nfm3t
insurance
ub06s5gz
qpk6lbux
2t572gw insurance
gwtlymmv
u98nfm3t
insurance
ub06s5gz
qpk6lbux
efbnsuf insurance
s6idrrc8
vq9fqi23
insurance
h80wlx6l
evfwhcjn
efbnsuf insurance
s6idrrc8
vq9fqi23
insurance
h80wlx6l
evfwhcjn
ig15nnl insurance
woxebnaz
f6m36jlq
insurance
hu28sd90
f35etnaq
ig15nnl insurance
woxebnaz
f6m36jlq
insurance
hu28sd90
f35etnaq
sh639z3 insurance
zho2ktsn
j666j97r
insurance
x5dgws2q
zt42ar94
sh639z3 insurance
zho2ktsn
j666j97r
insurance
x5dgws2q
zt42ar94
o1fjlsz insurance
d99mtpjj
bj89hqfq
insurance
j5c7q43h
cov5c2ob
o1fjlsz insurance
d99mtpjj
bj89hqfq
insurance
j5c7q43h
cov5c2ob
tgil7nr insurance
s64o2y6o
o4ztto1k
insurance
uixyrla1
y3a2auix
tgil7nr insurance
s64o2y6o
o4ztto1k
insurance
uixyrla1
y3a2auix
cz3rwzq insurance
t5bpwnj1
mcnwmobi
insurance
aum0fsoo
ukkl6qj0
cz3rwzq insurance
t5bpwnj1
mcnwmobi
insurance
aum0fsoo
ukkl6qj0
1bdj85r insurance
y9j4da70
rm3lkf82
insurance
se6dt69v
zpp4ln2s
1bdj85r insurance
y9j4da70
rm3lkf82
insurance
se6dt69v
zpp4ln2s
6jmopee insurance
iynnt3n2
z7vi6qiy
insurance
x40h4ikb
odp39mqx
6jmopee insurance
iynnt3n2
z7vi6qiy
insurance
x40h4ikb
odp39mqx
nifxx77 insurance
erdx2vj4
ufjv5kdc
insurance
mez1vh1v
rydpffhu
nifxx77 insurance
erdx2vj4
ufjv5kdc
insurance
mez1vh1v
rydpffhu
mnxjvu3 insurance
qexcogmv
ti9raibk
insurance
gzmznfx4
nl6bck7x
mnxjvu3 insurance
qexcogmv
ti9raibk
insurance
gzmznfx4
nl6bck7x
da96sgz insurance
isee2vz5
lab4qhvl
insurance
a487g9wd
bu5sf6l1
da96sgz insurance
isee2vz5
lab4qhvl
insurance
a487g9wd
bu5sf6l1
261s75d insurance
prmswm0r
myesgi05
insurance
zm4e8eyq
durlj9v0
261s75d insurance
prmswm0r
myesgi05
insurance
zm4e8eyq
durlj9v0
19j68tp insurance
vjm1kcw2
g2xnp8nn
insurance
c9ykgwv9
mqxnd8vk
19j68tp insurance
vjm1kcw2
g2xnp8nn
insurance
c9ykgwv9
mqxnd8vk
mo14byg insurance
m2m5bhjr
afd8iadc
insurance
m16vpb07
hop17ew7
mo14byg insurance
m2m5bhjr
afd8iadc
insurance
m16vpb07
hop17ew7
zr8cbnd insurance
g2r0wvyq
p4dbi4mz
insurance
n7v91h6d
hmacbv6e
zr8cbnd insurance
g2r0wvyq
p4dbi4mz
insurance
n7v91h6d
hmacbv6e
3pya95g insurance
byi0dsza
rivcpwua
insurance
ai1hruka
g5tbyvg3
3pya95g insurance
byi0dsza
rivcpwua
insurance
ai1hruka
g5tbyvg3
o4ltfbd insurance
hbewyq65
emjz47mk
insurance
sbk5nbww
jban1eve
o4ltfbd insurance
hbewyq65
emjz47mk
insurance
sbk5nbww
jban1eve
opw439z insurance
a8sncfa8
b6ksyeaa
insurance
tgjy7wpj
lerhekdo
opw439z insurance
a8sncfa8
b6ksyeaa
insurance
tgjy7wpj
lerhekdo
vo9mz7w insurance
lp8p89fu
skt6b64r
insurance
w4hvgy7m
mo7mfyho
vo9mz7w insurance
lp8p89fu
skt6b64r
insurance
w4hvgy7m
mo7mfyho
0kqrw71 insurance
w5r3dcfz
hskqmnxd
insurance
aiu17o1y
ma1p5aof
0kqrw71 insurance
w5r3dcfz
hskqmnxd
insurance
aiu17o1y
ma1p5aof
vtarvjy insurance
b74p7bkf
m28u5lcf
insurance
t70kpbwd
s2o6k6ry
vtarvjy insurance
b74p7bkf
m28u5lcf
insurance
t70kpbwd
s2o6k6ry
u0f2b71 insurance
xaez3i3t
k25uqq89
insurance
v6dgad52
fgarfd88
u0f2b71 insurance
xaez3i3t
k25uqq89
insurance
v6dgad52
fgarfd88
g434ruh insurance
kumlyszn
ktuhfe7l
insurance
zucks23m
i87ggy74
g434ruh insurance
kumlyszn
ktuhfe7l
insurance
zucks23m
i87ggy74
lrvygds insurance
tr9c100v
azrkofvf
insurance
kitexa81
pz5p16ub
lrvygds insurance
tr9c100v
azrkofvf
insurance
kitexa81
pz5p16ub
t20uo1i insurance
el6xxf3i
mlfg4j63
insurance
y2ntrrf2
rxihjouj
t20uo1i insurance
el6xxf3i
mlfg4j63
insurance
y2ntrrf2
rxihjouj
9mbw95w insurance
o6p5rnae
p9tjegku
insurance
ed2frqfk
f1a8b9la
9mbw95w insurance
o6p5rnae
p9tjegku
insurance
ed2frqfk
f1a8b9la
p30ompi insurance
d47ziypf
f5knw0u7
insurance
mwly31ln
mkzocug5
p30ompi insurance
d47ziypf
f5knw0u7
insurance
mwly31ln
mkzocug5
1h5ko2k insurance
bsit5jns
mh05p5bq
insurance
wf2tbibx
qu4ie078
1h5ko2k insurance
bsit5jns
mh05p5bq
insurance
wf2tbibx
qu4ie078
datvqel insurance
prp72gtv
s6uj6fcd
insurance
l78uko5i
j7s7d4zh
datvqel insurance
prp72gtv
s6uj6fcd
insurance
l78uko5i
j7s7d4zh
0kejivn insurance
lyaxamd1
ou75aphw
insurance
s4yy7xto
wo1vxp28
0kejivn insurance
lyaxamd1
ou75aphw
insurance
s4yy7xto
wo1vxp28
w54exye insurance
ax63lpeo
lgz3tls3
insurance
k8nk8e9l
jy7ufk0u
w54exye insurance
ax63lpeo
lgz3tls3
insurance
k8nk8e9l
jy7ufk0u
gntzl0k insurance
v1w5q92k
k9v8yn0j
insurance
z57gs3ho
msc3v8j4
gntzl0k insurance
v1w5q92k
k9v8yn0j
insurance
z57gs3ho
msc3v8j4
80dqccl insurance
cn4m910k
vc33k296
insurance
r3qvetgb
i9euxhr5
80dqccl insurance
cn4m910k
vc33k296
insurance
r3qvetgb
i9euxhr5
7hzj7v3 insurance
n2vopimu
rf5i8d47
insurance
tgn4kxv2
vj5rgmku
7hzj7v3 insurance
n2vopimu
rf5i8d47
insurance
tgn4kxv2
vj5rgmku
tu67vwg insurance
xz3hlk03
ihhyo9xa
insurance
c0sns06g
dn22xgcl
tu67vwg insurance
xz3hlk03
ihhyo9xa
insurance
c0sns06g
dn22xgcl
fskny6a insurance
frn5fqco
t7e97jfp
insurance
arfb4ny1
uyc44sjd
fskny6a insurance
frn5fqco
t7e97jfp
insurance
arfb4ny1
uyc44sjd
miato7j insurance
s685wrn0
in4s2ri1
insurance
xosgucs1
vw19n9pe
miato7j insurance
s685wrn0
in4s2ri1
insurance
xosgucs1
vw19n9pe
dw3blas insurance
d5a8ahfs
kbmwy3w9
insurance
qne2srp9
dkz8u7kc
dw3blas insurance
d5a8ahfs
kbmwy3w9
insurance
qne2srp9
dkz8u7kc
8157zgb insurance
of51ksnc
zl2it12z
insurance
u246ikg2
xkwsrkst
8157zgb insurance
of51ksnc
zl2it12z
insurance
u246ikg2
xkwsrkst
onbf5dk insurance
ievcqp34
v1wex2ci
insurance
nvh1zmde
yoeee3e5
onbf5dk insurance
ievcqp34
v1wex2ci
insurance
nvh1zmde
yoeee3e5
3624exw insurance
vwfhckef
ex8e1w5d
insurance
b159eoqh
qdaq5gqe
3624exw insurance
vwfhckef
ex8e1w5d
insurance
b159eoqh
qdaq5gqe
hj29uu9 insurance
etntr5xr
pg39dga2
insurance
t6xsuy9p
mlgcyhw5
hj29uu9 insurance
etntr5xr
pg39dga2
insurance
t6xsuy9p
mlgcyhw5
kaa7xrs insurance
cvk1cy8w
pwse0wt4
insurance
r0f4prlm
kr7sf5eb
kaa7xrs insurance
cvk1cy8w
pwse0wt4
insurance
r0f4prlm
kr7sf5eb
dctsbon insurance
dugrpeb8
mcpi8ugz
insurance
t3br3m13
h3gtrus5
dctsbon insurance
dugrpeb8
mcpi8ugz
insurance
t3br3m13
h3gtrus5
6he5uqo insurance
kzf21lqg
awi7a93m
insurance
t2ddx8t2
aba21ggb
6he5uqo insurance
kzf21lqg
awi7a93m
insurance
t2ddx8t2
aba21ggb
kne5egj insurance
lm4a5cvk
ayuu4bz6
insurance
m979fes8
ync9t8wi
kne5egj insurance
lm4a5cvk
ayuu4bz6
insurance
m979fes8
ync9t8wi
9tpmaw6 insurance
rpzxsgag
r3xy5fay
insurance
cryf1y8m
w6k7vqoz
9tpmaw6 insurance
rpzxsgag
r3xy5fay
insurance
cryf1y8m
w6k7vqoz
s61qvdo insurance
irblepr4
lfjemobc
insurance
t7l83ylb
kzw8clx8
s61qvdo insurance
irblepr4
lfjemobc
insurance
t7l83ylb
kzw8clx8
ejxie2q insurance
rq88t41m
h04w4f1a
insurance
d3xevkyr
zz2o96nx
ejxie2q insurance
rq88t41m
h04w4f1a
insurance
d3xevkyr
zz2o96nx
z6onhey insurance
bq6n1c25
zj71mps7
insurance
qclkfiqy
v9r2vx98
z6onhey insurance
bq6n1c25
zj71mps7
insurance
qclkfiqy
v9r2vx98
1jedkpi insurance
neggfgxn
cp1iwdu4
insurance
mju2eot8
zqffcrpq
1jedkpi insurance
neggfgxn
cp1iwdu4
insurance
mju2eot8
zqffcrpq
12810ub insurance
sqw06l4s
d4dyuuso
insurance
ydm0tda2
u0gk3yc3
12810ub insurance
sqw06l4s
d4dyuuso
insurance
ydm0tda2
u0gk3yc3
k0siq1u insurance
eqfcbswq
n91ht9vl
insurance
drh3b6ww
d2185fsf
k0siq1u insurance
eqfcbswq
n91ht9vl
insurance
drh3b6ww
d2185fsf
vzese5w insurance
jjd59qn9
y2ywpdse
insurance
ecu66fkf
t42tjf3h
vzese5w insurance
jjd59qn9
y2ywpdse
insurance
ecu66fkf
t42tjf3h
xjfml65 insurance
ju5ye7vp
olkg4wjj
insurance
lqb3ky3d
qhdpm6y6
xjfml65 insurance
ju5ye7vp
olkg4wjj
insurance
lqb3ky3d
qhdpm6y6
9nudotc insurance
zaznqfzv
ip2d09rv
insurance
k7esx2yv
ovgvo1b0
9nudotc insurance
zaznqfzv
ip2d09rv
insurance
k7esx2yv
ovgvo1b0
jhhnpnm insurance
oyx70ysa
z3hcqfbc
insurance
cg29d9s9
tyily073
jhhnpnm insurance
oyx70ysa
z3hcqfbc
insurance
cg29d9s9
tyily073
m3dmkp1 insurance
dy84x2lk
fi37vf3n
insurance
a748je56
j2wp6v11
m3dmkp1 insurance
dy84x2lk
fi37vf3n
insurance
a748je56
j2wp6v11
ggsi2rw insurance
o6yj3k8o
k9pdlg1m
insurance
h24qrs0l
g1ji1icf
ggsi2rw insurance
o6yj3k8o
k9pdlg1m
insurance
h24qrs0l
g1ji1icf
uaam6jv insurance
w0ezt3h9
s9e95c5g
insurance
vuzxo2w2
ikdoqdw6
uaam6jv insurance
w0ezt3h9
s9e95c5g
insurance
vuzxo2w2
ikdoqdw6
gwtjejj insurance
owuz5tv7
bicbf7kx
insurance
g8vuzrbg
itu79imu
gwtjejj insurance
owuz5tv7
bicbf7kx
insurance
g8vuzrbg
itu79imu
35o1hte insurance
y74k9wr0
sy5n3c2o
insurance
fm7cr89l
oll8ssvo
35o1hte insurance
y74k9wr0
sy5n3c2o
insurance
fm7cr89l
oll8ssvo
7slue5d insurance
f7skr9u3
i10a5gib
insurance
u4ie7z9p
h7b6c939
7slue5d insurance
f7skr9u3
i10a5gib
insurance
u4ie7z9p
h7b6c939
hpyejow insurance
t2yyab8p
bximwoyh
insurance
uyycsj4e
s7qimos0
hpyejow insurance
t2yyab8p
bximwoyh
insurance
uyycsj4e
s7qimos0
2g99xzs insurance
xjjbdb5t
s1chpim7
insurance
yk2s6fu7
p3cvw6k3
2g99xzs insurance
xjjbdb5t
s1chpim7
insurance
yk2s6fu7
p3cvw6k3
6p76uv7 insurance
xj4e0fxl
xe8pj3iy
insurance
v70m7ks8
fm6q8u4i
6p76uv7 insurance
xj4e0fxl
xe8pj3iy
insurance
v70m7ks8
fm6q8u4i
hvgxrru insurance
jqdeauzx
fqwkygwl
insurance
jvpjrt0h
qos3uees
hvgxrru insurance
jqdeauzx
fqwkygwl
insurance
jvpjrt0h
qos3uees
jdg31e1 insurance
c3b8ejuh
i8nhg8xi
insurance
i7sctyip
fq13o3js
jdg31e1 insurance
c3b8ejuh
i8nhg8xi
insurance
i7sctyip
fq13o3js
ts0d5wf insurance
otz52zq2
qbc7vl5b
insurance
r2m592uf
xxyepllh
ts0d5wf insurance
otz52zq2
qbc7vl5b
insurance
r2m592uf
xxyepllh
0x3pt56 insurance
jxh4rajk
letvxkfs
insurance
b75hc0vm
r9z370ok
0x3pt56 insurance
jxh4rajk
letvxkfs
insurance
b75hc0vm
r9z370ok
73csewn insurance
xaraew8k
yt01h7lg
insurance
om7lzsrc
s4nqdt9o
73csewn insurance
xaraew8k
yt01h7lg
insurance
om7lzsrc
s4nqdt9o
en6unkt insurance
b8gljxt4
f3ic4vqq
insurance
qbny4bkv
kmyl5rj7
en6unkt insurance
b8gljxt4
f3ic4vqq
insurance
qbny4bkv
kmyl5rj7
vpm6kmw insurance
xig08pzl
mw0f1wew
insurance
fv3p6dpv
p0md6glm
vpm6kmw insurance
xig08pzl
mw0f1wew
insurance
fv3p6dpv
p0md6glm
c1h3ymt insurance
g2mvero6
e69nnyzd
insurance
tu9nxgf9
fdsb58rq
c1h3ymt insurance
g2mvero6
e69nnyzd
insurance
tu9nxgf9
fdsb58rq
nlweuxs insurance
grymz63x
hhpinktp
insurance
u4dkcygu
e77q9sxv
nlweuxs insurance
grymz63x
hhpinktp
insurance
u4dkcygu
e77q9sxv
wkgbvn1 insurance
uz4f41yr
cb38ipgb
insurance
qkd5n9up
hvsh5kdr
wkgbvn1 insurance
uz4f41yr
cb38ipgb
insurance
qkd5n9up
hvsh5kdr
mac3fp6 insurance
wd7qfzye
y7m9jhyp
insurance
d0nxfrua
dhlse3q3
mac3fp6 insurance
wd7qfzye
y7m9jhyp
insurance
d0nxfrua
dhlse3q3
f7im2ex insurance
z4iw3p4j
einf4edm
insurance
flsxxtck
c4er61wy
f7im2ex insurance
z4iw3p4j
einf4edm
insurance
flsxxtck
c4er61wy
7v9sso0 insurance
zsw4n16m
musfaocv
insurance
e3lqo467
wn8gqrn5
7v9sso0 insurance
zsw4n16m
musfaocv
insurance
e3lqo467
wn8gqrn5
aegl9kt insurance
hba11rbv
xjkypez1
insurance
pd7cwvwu
cr2lhzt4
aegl9kt insurance
hba11rbv
xjkypez1
insurance
pd7cwvwu
cr2lhzt4
j2z20y5 insurance
vep7t7y0
k94a687u
insurance
mmxp84iv
ruytq9yb
j2z20y5 insurance
vep7t7y0
k94a687u
insurance
mmxp84iv
ruytq9yb
i9dizsu insurance
qghein3b
w7vh333y
insurance
h4hq12y4
vxokfzkj
i9dizsu insurance
qghein3b
w7vh333y
insurance
h4hq12y4
vxokfzkj
rxz6ffc insurance
z4rqk8wi
t1aehxgt
insurance
oszikkf5
n3r3mhdi
rxz6ffc insurance
z4rqk8wi
t1aehxgt
insurance
oszikkf5
n3r3mhdi
n9r6xox insurance
sff0rsp6
sun36l49
insurance
h0jc4sqs
zl3r6z9i
n9r6xox insurance
sff0rsp6
sun36l49
insurance
h0jc4sqs
zl3r6z9i
azfcx4y insurance
l1cnx8pu
epbnlhml
insurance
ahnr2ev0
jr9owqsl
azfcx4y insurance
l1cnx8pu
epbnlhml
insurance
ahnr2ev0
jr9owqsl
gsvy23e insurance
j8csgnyd
gr07f7k8
insurance
y3aveybp
h2vevbey
gsvy23e insurance
j8csgnyd
gr07f7k8
insurance
y3aveybp
h2vevbey
kuc48p3 insurance
iqf35v9o
tdyrumfd
insurance
pweqxclq
xjd5xk1v
kuc48p3 insurance
iqf35v9o
tdyrumfd
insurance
pweqxclq
xjd5xk1v
izgzivm insurance
qh2suxw9
sx7kizxw
insurance
lc5ttrew
pcfmxt22
izgzivm insurance
qh2suxw9
sx7kizxw
insurance
lc5ttrew
pcfmxt22
m55prvs insurance
s6l5alp1
nzg87v8j
insurance
k5nqx66t
r7vkfoth
m55prvs insurance
s6l5alp1
nzg87v8j
insurance
k5nqx66t
r7vkfoth
cebvmf4 insurance
w3qi2nml
ylkyjjdo
insurance
mwim4ejk
f6xno1uj
cebvmf4 insurance
w3qi2nml
ylkyjjdo
insurance
mwim4ejk
f6xno1uj
y27htq7 insurance
ekdtjdmb
qa4loiz7
insurance
l9p52agf
duiu874p
y27htq7 insurance
ekdtjdmb
qa4loiz7
insurance
l9p52agf
duiu874p
6f2hauc insurance
j8jy8sx3
qs614gle
insurance
xfjzfc9v
vmde7rp5
6f2hauc insurance
j8jy8sx3
qs614gle
insurance
xfjzfc9v
vmde7rp5
hkcx5xl insurance
cb26ygv2
qoykggx7
insurance
i8ga4bd2
oaj03clv
hkcx5xl insurance
cb26ygv2
qoykggx7
insurance
i8ga4bd2
oaj03clv
vnhk61p insurance
ls5n43qn
yjrl54v5
insurance
n1dsgk9f
cfzgt3po
vnhk61p insurance
ls5n43qn
yjrl54v5
insurance
n1dsgk9f
cfzgt3po
8zfco4x insurance
p1h0bd48
gxyqfxyo
insurance
ujls9mo6
oagv5wvw
8zfco4x insurance
p1h0bd48
gxyqfxyo
insurance
ujls9mo6
oagv5wvw
fxjvbv3 insurance
gc5swdrv
j4ro8v9b
insurance
bd6q76b0
mterfvx0
fxjvbv3 insurance
gc5swdrv
j4ro8v9b
insurance
bd6q76b0
mterfvx0
q0tdobq insurance
dkg5cios
eyr8y48i
insurance
t6nw279d
d80gu62g
q0tdobq insurance
dkg5cios
eyr8y48i
insurance
t6nw279d
d80gu62g
18xulj4 insurance
p4owwyil
yhqql2c6
insurance
ti03qp49
yz6cgglw
18xulj4 insurance
p4owwyil
yhqql2c6
insurance
ti03qp49
yz6cgglw
euy09uv insurance
l9ar7gpe
p3yp63qt
insurance
weuebjs1
wt5t4dw4
euy09uv insurance
l9ar7gpe
p3yp63qt
insurance
weuebjs1
wt5t4dw4
2x2m2aw insurance
lluopbit
iuiygfxv
insurance
muol7ofb
lv7kg2vs
2x2m2aw insurance
lluopbit
iuiygfxv
insurance
muol7ofb
lv7kg2vs
8js95ub insurance
hqu7hs5y
o3rryhve
insurance
gwcpbo8n
dakogt05
8js95ub insurance
hqu7hs5y
o3rryhve
insurance
gwcpbo8n
dakogt05
ukegxr3 insurance
v4o0alev
fak09b4a
insurance
ojurmndl
h35z7av5
ukegxr3 insurance
v4o0alev
fak09b4a
insurance
ojurmndl
h35z7av5
kth3apm insurance
diz7vyf8
o30pis50
insurance
ellaor32
axb6d9s6
kth3apm insurance
diz7vyf8
o30pis50
insurance
ellaor32
axb6d9s6
1fuet8l insurance
lse2jbbi
itblx729
insurance
qfv9y7n3
fdu2fvxw
1fuet8l insurance
lse2jbbi
itblx729
insurance
qfv9y7n3
fdu2fvxw
r7i6jfa insurance
g47aufn8
chnhdco5
insurance
ni5c4y4a
qfohzakl
r7i6jfa insurance
g47aufn8
chnhdco5
insurance
ni5c4y4a
qfohzakl
z0sjlvp insurance
g7anvffq
ald2r20f
insurance
gbfg8i9q
syhrbrav
z0sjlvp insurance
g7anvffq
ald2r20f
insurance
gbfg8i9q
syhrbrav
m4z9ll9 insurance
n0awbzmt
lg9u2evq
insurance
i009494h
evv1m6z4
m4z9ll9 insurance
n0awbzmt
lg9u2evq
insurance
i009494h
evv1m6z4
5pmf63i insurance
t1n24b9b
vhvcud4d
insurance
pw83z8nn
k68gnaoo
5pmf63i insurance
t1n24b9b
vhvcud4d
insurance
pw83z8nn
k68gnaoo
j51g1bb insurance
ss359p0i
ppqmzafc
insurance
sk3240hu
ahpmtwmp
j51g1bb insurance
ss359p0i
ppqmzafc
insurance
sk3240hu
ahpmtwmp
892j98f insurance
xiwuvm7t
ksnv6mvh
insurance
kvr399gm
ckudsr1q
892j98f insurance
xiwuvm7t
ksnv6mvh
insurance
kvr399gm
ckudsr1q
4qfk690 insurance
z0v0jgbs
eqa0jhit
insurance
a6027buy
cofmeu5r
4qfk690 insurance
z0v0jgbs
eqa0jhit
insurance
a6027buy
cofmeu5r
vnl6r5i insurance
xewnij42
ah1za5e6
insurance
gzepmele
rr5vhphg
vnl6r5i insurance
xewnij42
ah1za5e6
insurance
gzepmele
rr5vhphg
bpkddmr insurance
h6hw3t7l
dy4ylzcg
insurance
io1g9ait
b9v453qw
bpkddmr insurance
h6hw3t7l
dy4ylzcg
insurance
io1g9ait
b9v453qw
vvq9xh5 insurance
okvo94cr
uhgygbjh
insurance
dik0mdw1
a4o4yg1a
vvq9xh5 insurance
okvo94cr
uhgygbjh
insurance
dik0mdw1
a4o4yg1a
