ok so grey rogowski is not taking questions but maybe someone can help me with a detail of his greene and greene style sideboard. i’m ready to put in the panels and he says after he sets the reveal he then pins the panels with 1/8 inch dowels. but won’t he have problems when the panels expand and contract? maybe for some reason this is no problem. or should I dry fit the panels, set the reveal, drill the holes for the panels, take it apart and make the holes into notches and then put the whole thing back together so the panels can move over the dowels. help, I’m ready to buy some of those rubber balls if no one can give me an answer.
sean de queiroz
Edited 4/10/2009 11:52 am ET by seandequeiroz
"he then pins the panels with 1/8 inch dowels. but won't he have problems when the panels expand and contract?"
You pin the panel in the middle, top and bottom, so expansion,contraction is equalized. We used to just assemble our rails and stiles with the panel in place and shoot a pin in the center, top and bottom of the panel through the rails to secure the panel in the center and a few pins in the joints of the rails and stiles so we could take them out of the clamps immediately and glue up another door without waiting for the glue to dry while clamped.
Sean, What Rick stated works fine, I use a 23 ga pinner.
Tom.
Rick's way is the simplest and most accepted way. I do not have a pinner so I just use a 3/8 or 1/2" wire brad nail.
mike
The posts above have given you the answer, but I would have explained it differently, so just in case:
A solid wood panel (as opposed to ply or mdf where there is no expansion issue) only expands in width, and not perceptibly in length. The end grain sides never get further apart if you will. If you are only pinning the middle of these end grain sides, the wood can still expand and contract in width on either side of the pin (i.e., the pinned point/mid-line is the only thing being held still.
thanks, i guess i was thinking he pinned it in four places but reading it over i see that you guys are right and if you just put two pins in the middle of the end grain side there should be no problem. thanks for the help sean
