I have a Dewalt miter saw and a shop-made framing clamp. I am about to start a picture frame project. I have not made picture frames before, but I have cut and fit miters. My first job with the Dewalt 716 was window trim and crown molding, which went well. I have seen a tool called the Pushmaster which is used to insert metal clips (v-nails) into the back of picture frame corners. This tool is expensive. Is it worth the money? How well does it work? I will be using pine molding to start and hardwood molding later. Is there a good alternative to the Pushmaster?
Probably the two most critical things in making frames is making the opposite sides EXACTLY the same length and then having 8 miters exactly 45 degrees. Personally I hate those V shaped joiners. My preferred method is to rub the glue joint with hide glue and let it set for a day or two. ( I don't clamp). And then spline the miter with a contrasting lumber. Nothing is going to tear a splined joint apart.
Vanquish those V-nails! ;-)
I agree with Bruce about getting the corresponding sides exactly the same length, and tuning the miter angle to a precise 45°. I now use a (well-tuned) miter shooting board to accomplish both tasks. Previously, I used a bench disc sander, clamping a block to the table and tuning that to 45°. The shooting board is much more accurate, however. Either method also produces a nice smooth surface for gluing.
Splines are a great way to strengthen the joint, particularly for larger frames that will be carrying a substantial weight. For small frames not intended for hanging, however, splines might be overkill.
OH, and don't forget to sign and date the backs of your frames. Your great-grand kids will appreciate knowing that you made the frames.
