I am going to purchase a panel raising and rail and stile router bits. I will be using them in a router table with a PC 7518 3.25 HP fixed base variable speed router.
The primary intended use is for making raised panel doors. Do you have any recommendations as to manufacturer, style, etc. Should I buy a matched set? Ones with back cutters, etc?
I'd look into the CMT sets with backcutters.
JD,
Another poster recommended CMT and you can't go wrong there. Other top choices are Amana and Freud, of course. I buy most of my bits from MLCS because they are less expensive and I have had no problem with them. I have purchased two different sets of matched rail and stile bit and two styles of raised panel bits from them; all have worked just fine. In addition, I purchased a back-cutter bit so I can use it with either of my raised panel bits or any others I might purchase. A raised panel bit with the back cutter integrated into it might be a better way to go; I just wanted to save a few bucks and have the bit seperate. If I were a full-time shop, I'd go for the higher-priced bits, but most of my work is for our own house.
http://www.mlcswoodworking.com/
Bill Arnold - Custom Woodcrafting
I have mostly CMT and like them very much, but I have recently bought some Woodline bits and shaper cutters. Much cheaper and lifetime guarantee. Make 2-3 passes using a router bit with a lower speed for raised panels. You can use a piece of phenolic clamped to your fence for the first cut, take it off for the next, then have it worked out where your final cut is a small clean-up cut. End grain first and work yourself around.
For the frame cut the long grain (machine WITH the grain)of the rails and stiles first , then the end grain for the cope cut. Be sure to back'em up.Please be careful. Any questions you can write....
Rick
I've had great results with CMT, using the same PC router. I purchased mine as a set at a woodworking show in Detroit a few years ago. I don't recall the model, but the set had raised panel, cope and stick, miter lock, and a couple other bits.
JD
I have two sets of CMT bits (different profiles) and all three Whiteside sets, and have good luck with both. The Whiteside bits stay sharper longer. I guess that would be because of a higher quality carbide, but I'm not an expert on carbide, or anything else, for that matter. I probably have a total of about 30 whiteside bits, and am very pleased with them. I just started buying CMT bits, because Woodcraft has them, and they are frequently on sale there. If you are not banging out doors and panels all day long, I think you'll be happy with either.
JC
I recently did a kitchens worth of cherry doors & end panels using MLCS's katana bits with a backcuttter and had excellent results. You need to run the bits at a slower speed to avoid burning particularly in cherry. Art
With any of these large-diameter bits, you need to run them at a low speed. The reason being that, for a given rpm, the velocity of the outer edge of a large diameter bit will be higher than that of a smaller bit. Running at too high a veloicty would be unsafe.
Horizontal panel raisers MUST be used on a variable speed router, usually set around 12,000 R.P.M. follow instructions that come with the set to the letter...
