All,
I’m just finishing up a replacement center island for the kitchen and it is painted off white. I used two coats of oil based primer and two coats of Latex semi Pro classic. I’m surprised at the flatness of the finish. I’m wondering if I can wax and when or should I go another way? thanks
Did you use a "flat" paint? You may need to use a "satin" or a semi-gloss"
Dave45,Sorry Dave, I left off the semi-gloss part. Although, it appears flatter than eggshell.
I've used a Kelly Moore latex paint that is formulated for "heavy" use (e.g. doors, tables, desks, etc) that came out very well.I've also lightly scuff sanded latex and shot polyurethane over it to add durabliity.
Dave45,Do you think the varnish would hold over the latex....maybe a water based poly?
I assume you mean Sherwin-Williams Pro Classic? I, too, have noticed that the semi-gloss is surprisingly flat. But there isn't any standard for what "semi-gloss," "satin," etc. really mean, so I guess you get what you get.
I don't think there's any reason that you couldn't wax it, with the caveat that future recoating will require more work to strip the wax.
saschafer,Yes, the SW Pro classic is what I used. I'm shooting for a rubbed out look..not glossy but not dull either. I'm kinda wondering if semi is this flat how flat is satin.
Your best bet is to apply a coat or two of a gloss over what you have. Test it on some inconspicuous spot first to be sure it's what you want.
Wax will not provide much more in the way of gloss and once you start with wax, you will need to continually re do it. Wax is not good in a kitchen environment. Things like oil and moisture just make it gummy.
Howard,All and all, its my own damn fault. The first SW store I went into(locally) offered to open the cans and produce a sample once swmbo had determined the color. I went to the second SW store up in NH to buy the product...to save on the tax...forgot all about the testing.
I've used the same combo. SW Pro-Classic semi gloss is flatter that other Semi-Gloss. I usually sand the primer before shooting the top coat and have discovered that that produces a bit more gloss.
Quipstep,I can't sand the prime coats now but I was wondering if a light sanding and a third coat of finish would produce better results?
Edited 4/17/2009 6:11 pm ET by BG
I think it would, but in my experience, the pro-classic takes quite a long time to get hard enough to sand dry. I have wet sanded it using naphtha as a lubricant. It worked, but was messy.
Quickstep,I've got lots of leftovers or both primer and finish, it's time to grab some scraps and experiment...
