I have a couple friends that has a thick old pine table from the 70’s (you know the type), it has some fairly deep scratches in the top and they want me to refinish it. It is a dark walnut brown stain and my question is this; Would briwax or liberon black bison wax do the trick here? Or am I going to have to take it down to the bare wood and start from scratch? The table has matching chairs and I don’t really want to have to fuss with matching or refinishing the whole dang thing as a “favor”. Any advice would be appreciated.
-Floyd
Wax isn't going to fix things beyond a very short term cosmetic fix at best, I'd clean the table well--soap and water then naphtha. That will give you a better idea of what all is needed. i'd also test to see what the finsh actually (most likely lacquer if this was made in a factory).
Have the scratches penetrated to bare wood, or are these mostly just deep depressions that didn't actually cut the finish top coat? You should be able to fill scratches with tinted shellac or lacquer, then scrape or sand level, and finish with a clear coat of shellac or lacquer so you can buff to an even sheen over the entire top.
Table Top
Fairly deep scratches can only be removed with a complete strip, sand, and refinish. If you just want to color over the scratches there are some ways to do it without refinishing.
SA
Ha, ha, ha. That's it huh ?
>If you just want to color over the scratches there are some ways to do it without refinishing. <
. . . but . . .
((we aren't going to tell you about those)).
I guess.
or
You could . . .
. . . play it up . . .
WOW ! This piece is well on it's way to being an "antique" (it is 40 years old after all).
Look at alll that "character" in the "patina" in the top.
We don't want to destroy the "value" of the piece by changing the "original" finish.
Rub on some "special" "lemonOil" to "feed the wood" and viola ! Happy campers.
Technique
Are you grouchie today roc ?
It's better if the poster asks a direct question. Aren't you the one who always says - " I explain in extreme detail and the poster never responds" Na dude - na dude - *&))(&^%% not me !
I'm not holding back - I just want to try to help based on poster's direction. He'll say exactly what he wants to do - give it a chance. Go pick on steve if you feel like a fight - Maybe I'm better off talking to : Queenmasteroftheuniverseandbabybunnytrainer - at least the Mrs. has an even temperament
SA
I better stay here and play devils advocate
It would be hard to argue with Steve. He is thorough,and patient and right and highly experienced, well balance, broad minded, well versed.
Nah that would be a tough one. I would just wind up saying stupid stuff like wood doesn't grow on trees and forging wood with a black smith's hammer is the best way to thickness planks.
I think he wouldn't raise an eye brow.
Emphasis on the quotation marks
You know.
It's BS
Go into any grocery store or Ace Hardware or Dime store (do they still have those ?) and walk up and down the isles until the furniture care products are found and there on the shelf is Pledge and several other products that have silicone and other crap in it that makes the surface look "restored" with only a spray and a wipe. And they put lemon fragrance in it. No body knows why.
Simple solutions for people in a hurry. I don't mean it is a good idea. Sounds like the owners of the table want an inexpensive solution for a basic table.
If they learn to be OK with the surface that is on it, scratches and all then every body is happy.
