Hi all, run across a bit of a problem. I’m making a cupboard for home and thought I would finish the internals and shelves before glueing up. I’ve applied 3 coats of oil to one side of the shelves (solid wood) over the last couple of days and they have cupped slightly. I presume this is becase there has been a fair amount of rain in the last couple of days and the unoiled side has taken more in than the oiled side. Is is better to oil the other side straight away or let it settle back down before oiling and glueing?
For the next time, is if better to oil each side alternately to limit the time that there is more oil on one side than the other?
Thanks in advance.
Roger
Edited 5/1/2006 5:38 pm ET by Roger
What type of oil did you apply? Boiled linseed oil and pure, real tung oil have very little watervapor resistance and should not have caused any cupping.
Roger, if it's a cupboard it will surely have something like doors that will enclose those shelves and other internal parts?
If you've used pure oil finish like boiled linseed oil or pure tung oil you ought to think about the fact that these oils if used in enclosed spaces smell really bad-- something between a well established fungus and sweaty socks.
You'll almost certainly need to apply some kind of film forming polish over the oil to prevent the smell. Shellac works quite well usually, and so does the (mostly) sprayed nitro-cellulose family of finishes. Slainte.
Richard Jones Furniture
Roger,
Once the other side is oiled, the shelves will straighten out if the only cause of the problem was the unequal absorption of moisture, nothing will be gained, or lost, by waiting. However, any flatsawn board, no matter what the finish, will cup some as it gains or loses moisture, so some of the cupping is normal and to be expected, and will change with the seasons.
Thanks all for the advice. The product I used was Liberon's Finishing Oil, an amalgam of thins. I think its base is Danish Oil, and then with a host of other things. There isn't a list of ingredients, but it's designed for use on worktops and bathroom furniture (should have been a give-away if I'd been thinking) so presume it is formulated to reduce or slow moisture transfer.
Thanks for the sanding sealer tip. I've prepared a piece with a wax finish which seems to reduce the smell, but I'll now prepare a test piece with a sealer as well.
Roger
