greeting all, I have several Norton Water stones, and when I am not using them, I store them in a tub submerged in water. (sharping instructors suggestion)
questions is, is this proper storage of the stones? or am I saturating the stone with water making them softer than normal?
thanks for your help.
Snapperhead
If the instructions suggest it I would think it is OK. I've stored my Japanese stones in water for over 10 years now.
Oh Snap,
as the young kids say. You pushed my button. See pic. I am all about the Norton stones and store the 700 and 4000 in water all year. There is a king ( brown color ) 1000 in water all year as well. Absolutely no problem. No softening that I detect. No crumbling or any other problem.
I use Tupperware with lids and burp a bit of vacuum as per normal tup use. The water never gets slimy even after a couple of months. With no lid they got slimy in a couple of weeks.
I do not rinse the stones in the storage water I rinse them under the kitchen faucet with cold water ( never use hot or warm on the stones )
The 8000 does not benefit from being immersed so it just gets run under the faucet to wet and then rinsed and put in a tub on edge with other sharpening tools and a breathable cover. I also use a Shapton ( green ) 2000. If I did it all over again I would get all Shapton but that is another post. The Nortons are perfectly fine just that the Shaptons are even better and do not require soaking.
>Softer than normal<
you can't get softer than the Norton 250 what ever. It is a soft piece of poo even without soaking. A truly useless stone. Unless they improved it.
roc
Edited 11/22/2009 1:04 pm by roc
One thing that is a good tip is to flatten the stones and then using the stone flattening stone put a slight bevel all around every edge of the stone just so there is not a sharp corner any where. This prevents the edge of the stone chipping like an arrow head from temperature fluctuations like if you forget and rinse the stone under warm water.
I have actually experienced the edge chipping and the bevel prevents it.
roc
Yah know . . . ( and I say this in solum confidentiality ) the true sharpening connoisseur has his ( or her ) water collected and shipped in from the sacred spring at Kiyomizudera, Kyoto Japan.
Anyone else is just fooling around and not a follower of the TRUE sharpening WAY.
The second pic is me there on vacation. I like to blend in.
roc
"The second pic is me there on vacation. I like to blend in."
Huh. Now we know why they call you "roc".
