Good Morning Mr. John White
I´m a new woodworking member from Brazil. I´m trying to build the New Flenged Workbench (By John White), i signed the websit expecting that it has the complete plan to do it but unfortunatly it doesn´t. So I ask if you have the plan or some other information for me to build this workbench, such as the base dimensions our cutting diagram. I aprecciate if you can help me . (Sorry about some possible english mistakes).
Thank you,
Antonio Marceneiro
Antonio,
Welcome to the Knots web site. Unfortunately, other than the information in the article there are no plans for the bench.
None of the dimensions are critical, the parts just have to fit together. You can make the bench taller or shorter to suit your height and longer or shorter to suit the size of your shop and the type of work you do.
If you go to the "advanced search" function which is at the top left corner of the Knots pages, and click on it, you can search this site for the "newfangled workbench". This will get you to a lot of additional information about the bench but still no actual plans.
Since the article was published, I have received hundred requests for plans for the bench, and lots of notes from people who have built the bench without plans. I will finally be making a set of plans, including construction and use information about the bench, that should be available in April or May of this year.
Your English is fine, certainly much better than my Portuguese. Just be careful when doing the search for the bench information that you spell "newfangled" properly or you will confuse the computer, which isn't very smart.
Good Luck and Happy Holidays,
John
