I am the proud owner of a 24″ double drum sander. I bought it used and it has dual aluminum sanding drums. I understand that it’s common to install different grit sandpaper on each roll, one coarser, one finer. But what grits are recommended?? I plan to sand cabinet doors, small tabletops, and shop cut veneers (veneers are the main reason I bought a drum sander). I’m thinking 80 grit on one, and 120 grit on the second, but I have NO experience with this machine. Any suggestions?
Thanks….Jeff
Those are the grits I run. Very good results, remember to set the second drum a hair lower than the first.
jeff, what brand of sander is it? If it is the Performax, there is an owners manual on line that explains the grit combinations.
Steve
Grizzly G1066. Manual doesn't mention anything about what grit to run...
jeff, here are the combinations suggested in the Performax SuperMax 25X2 manual:
36, 36
36, 60
36, 80
60, 80
60, 100
80, 100
80, 120
100, 150
120, 150
120, 180
150, 220
Steve
