Folks,
I don’t do bowls (at least not yet) and I don’t use a lathe all that much anymore (lots of craftsman furniture), but I still do turnings now and then. I have done many turnings over the years that vary from 1/2 inch to 6 inches or so in diameter to over 3 ft in length. Sometimes I had to splice two together to get the length I needed. I have done all this with (ugh!) a 40 year old Sears Craftsman “tube” lathe that I bought NEW. I tried a friend’s Delta 46-715 and liked it. I also know that Delta has a new midi 46-460 lathe that appears to be very nice. The 46-715 has been discontinued, so I would probably have to buy it used.
I don’t want to spend over $600 or $700 (would prefer less) because I don’t use the lathe a lot, but I would like the smoothness and chatter freedom that I can expect from a quality lathe. Although I know it would be nice, I don’t want a used 400 lb. behemoth. I have read about the Grizzly and Shop Fox lathes, but I also heard the mixed results. The Sears has made a smooth cut hard to do (possible, but hard).
With these facts in mind, I would like to ask you-all what you would suggest.
I just love to show baby pictures.
He's a lathe for cutting metal. Sorry couldn't resist. Handy though; cuts threads etc. in wood. Probably bad for the lathe to use it all the time for wood. I don't much.
A bit out of the price target but I didn't buy a nice cabinet saw which would cost about the same.
roc
Roc,
Do you find any limitations using the metal lathe on woodworking? I want to buy a lathe to turn banjo rims. All the banjo guys use metal lathes for the accuracy, but I'm wondering if I'd be sacrificing functionality during other turning operations.
Edited 6/22/2009 3:14 pm ET by Quickstep
>Do I find any limitations using the metal lathe on woodworking?Quickstep,Well let me say this about that . . . a metal lathe is a miracle to have around . . . for metal work. I was mostly kidding when I suggested it for your average wood project.It is great for threads in wood. There is an article where a disabled woman uses a largish, old, rather worn metal lathe to turn everything; bowls, legs etc. I think I saw the article in Woodwork mag several years ago.For the everyday wood lathe user the wood fibers will get into the works and probably mess it up for precision metal working. I have not turned enough wood on mine to be a problem but I clean it well.Probably need to talk to the banjo guys to get accurate info. I already had the metal lathe many years before I even considered doing any wood working. Woodworking lathes are relatively cheep so why not have both. Or if you are interested you could get the metal lathe and use it to make the wood lathe. There are kits out there as well; or there used to be.For turning legs one would want to remove the carriage and cross slide and install the wood working lathe equivalent because one could work much faster. I would guess this to be true anyway.And then there is the problem of wet wood turning. Not good for the metal lathe. Not good at all.Sounds interesting though. If you could post some pics of banjo makers at work that would be great.rocGive me six hours to chop down a tree and I will spend the first four sharpening the axe. Abraham Lincoln ( 54° shaves )Edited 6/22/2009 9:14 pm by roc
Edited 6/22/2009 9:16 pm by roc
I'd think you could grab a variable speed Jet mini lathe with a bed extension and do spindles all day long. For that price. It won't be all the frills and stickers of the bigger models but it fits your budget and it actually has enough power to turn something with.
Real trucks dont have sparkplugs
Would you consider a used lathe? Craig's List is a great source for used tools, and I see lathe's on the Seattle list regularly. Prices should be pretty good these days.
I’ve been known to turn a bit and if spindles are your only goal look for a nice used lathe. There is little to ware out and used ones are quite reasonable in price. I’ve see older Delta 12 x 36 models for as little as a hundred bucks, even if you have to buy a motor and build a stand you end up with a great machine.
Oh yes, I am looking at the used market on Craig's list. There is one good old Yates American that looks like it is priced a bit high and I don't think I want a 400 lb. plus unit. I think a decent Delta was on there, but it went before about the time I started looking. So, no, I have no problem with a good used lathe. I would REALLY like a 45-715. It is a real nice lathe that would fill the bill well.
ERic,
I am not that much into turning , but my 15 yo son has gotten hooked on it, I don't know sometimes if it's the turning that he likes so much, or the instant results. He made a couple of beautiful Pens for Fathers Day, for his Grandfather and myself.
He did his homework on whats on the market without having to go broke, he settled on a Rikon. It cost him just over $250.00 plus tax. I guess you can add extensions to increase the lenght of the bed.
Taigert
Eric, I have the Yates- American lathe about 50 years old, bought ten years ago for about $1000. It's great, very steady, good varialble speed system. I recommend it. I was able to disassemble mine so that nothing weighed over 100#, and I at age 70 had no trouble getting if down into my basement. I don't plan on moving it out!
Tom
Well here's the good news. First let me state how much I hate Sears. They are the last people I would buy a lathe from, but I did!
Not that tube thingy you have but a cast Iron swivel head lathe 16"x 43 inch. it weighs 308 pounds! Sears sells it for about $500 which is right where Grizzley sells their copy of it..
However if you buy during the sales you'll get 20% off. Take a floor model and there's an additional 10% discount and then sign up for one of their credit cards and it's another 10% off. That means you can walk out of the store with it for only $324.00 when the bill comes won your Sears credit card pay it off in full and laugh up your sleeve..
Go to http://www.grizzly.com and look for model G0462.
It's a fine lathe trouble free for over 7years for me.. and I can with sharp tools get the wood polished looking better than I can sand it..
