I have a need for just 25 feet of edgebanding to match some Melamine shelves. The Melamine is wood grain to look like Pear wood. I’ve found it online but it comes in 300 foot rolls.
Does anyone know where I can order a small quantity of this PVC edgebanding to match my Melamine?
Thanks, molten
I think I saw some at Home Depot the other day -- I was looking for white, but pretty sure they had the wood-pattern too. It was underneath the melamine board stock.
pearwood melamine? or is it hard rock maple melamine? You'll have better luck finding the hard rock maple. If you need to match the melamine exactly, you could try ESI4service.com and you could probably cross it using the mfg #. I believe they have a minimum order, Fastcap also has peel & stick edgebanding in 50' rolls, I believe they have HR maple available in that.
Try contacting FramaTech in Los Angeles. They are a edgebanding supply company. You might be able to get them to give you a sample roll?. By the way, the thin pvc is usually only around 3-5 cents per foot(unglued)so y you won't be to broke if you can only get it in 350ft. I buy 1mm thick edge tape from them for 10cents a foot in 350ft rolls. I do think they have short rolls(50') too. An old catalogue has preglued for 9cents per foot. Seems that the thin pvc tape may only come in 600' rolls
Best way tro get a match is to find the pattern on plastic laminate(Wilsonart/Formica/etc) and give that to them. Most of there stock is inventoried that way
Try calling them 800-622-9663
