Is the phenolic table really better than the MDF tables? I am looking at both the Jessem and the Kreg ones. I will be also getting the Mastr lift. I will need it to have a 9 1/4 x 11 3/4 plate opening for my 3 hp PC router. Appreciate comments on what you own and what you would recommend. Thanks
It probably won't help you to mention it, since you can no longer buy one, but the best router table top I've ever seen and used is the Veritas 1/4" thick steel plate item with built in universal router-holder clasps underneath.
I mention it because such a thing has many advantages over the now ubiquitous MDF, phenolic and similar tops.
* Being thinner than MDF et al tops, it allows more of any router bit to project above the table.
* Being steel, it remains dead flat forever. (In fact, the Vertits item was made with a tiny upward bulge centred on the router hole, calculated so that the average weight of a 3HP router hanging underneath would pull it dead flat).
* Being steel, magnetic featherboards can be used anywhere on the table, unfettered by the need to use them in a tabletop groove or track.
* The steel top can be polished to a very fine slipperiness, with no drag on the workpieces.
Could such a thing be easily made from high quality sheet steel, using metal working tools? I've often wondered but, given the longevity of the Veritas top I have (over 20 years old, mine, and still perfectly flat) there's been no need to have a go at making myself one.
There are some apparently high quality phenolic tops about. But the glue + wood dust cores can so easily sag, break or otherwise degrade. Even a very slight sag or other distortion can ruin the performance of the router in making a perfect cut.
My suggestion is, as always it seems, build your own.
I built mine from 3/4" melamine laminated to 3/4" MDF. This resulted in a thick, stable and durable top. Plus it could be any size you want or need.
I will add that the router is attached to an insert plate, 1/4" thick, so the table thickness has no bearing on how much bit can be projected.
I frogot to mention, the cost can be much less as well.
The phenolic is probably better than the mdf but it is still too flexible and brittle to make a good table, the aluminum ones are a big improvement.
Cast iron if you can find and afford it. I got mine 20+ years back, it's mounted as the right wing of my tablesaw. It came with a plastic plate, I replaced it with an aluminum one.
I also had this concern about sagging router table tops. With some planning and design, I built my router table top as a torsion box with a center square opening for the router. It will never sag. 15 years later and it's flat as can be..
Norman
I made mine from 12mm compact laminate sheet - is that 'phenolic'?
I made a double layer - the top made of 3 pieces which were glued to the bottom sheet in a way that created 2 slots for a mitre gauge or sled. I chose the material for the sled/mitre guides and used those as spacers when gluing up. This allowed an accurate sliding fit without having to machine out the slots.
I constructed my router table top as a torsion box with a centre square opening after some thought and design. There are a few other samples at Bergen Furniture & Design.
I use a 20 yr old(?) Rockler router table top - 2 pieces of MDF covered with Melamine. At some point I constructed a torsion box as mentioned above to stabilize/flatten it a bit. I use it with a Rockler pro plate. All works fine. I also use a a Jessem 4010 Masterfence II with it...really like that fence a lot!
Incra makes good router tables but I don't know if it would work with your existing lift.
