I need to make some decorative window mullions for 4’x6′ acrylic storm windows. Can anyone suggest a simple table saw or router jig for this? I am considering using 1/2″ square stock.
The easiest thing to do is to start with a wider board, do all of the molding, etc., then slice the finished mullion off the edge of the board.
There is also a video by Steve Latta here:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=5221
That's a good video, but in my book, that guy is making a big safety mistake by reaching across a running saw to pick up those pieces behind the blade! Gave me the willies!Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
"...that guy is making a big safety mistake by reaching across a running saw to pick up those pieces behind the blade!"
I noticed the same thing.
I use a couple of microjigs to keep the hands away, and just let the pieces either pile up well behind the blade on the outfeed table, or with the microjig if the pices are shorter in length, I'm able to bring the remaining stock and the small cut pice back to the front of the blade together in a more safe controled manner and I stay away from the spinning blade. For long stock the second one comes in handy to help keep downard pressure as I feed it through.
http://www.microjig.com/GRR-Ripper%20DVD%20-%20Gallery_4.htm
As to the original question, lets say a 3/4" wide mutton as an example, you could run the profile edge on the top and bottom of a wide board 4-6" route a groove in the top and bottom face and then rip on the table saw. Do that on the left and the right side of the board, and you could get two pieces. Just M2CW.Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
Thanks Steve, the vedio was great. So I get that I need to run the dados across wider stock stock then rip it into the mullions. Any good jigs to make sure the dados are spacd evenly so the mullions come out even and square?
Let's say you have three boards that you've thicknessed to 1/2" thick (the final width of your mullions). After jointing the edges of the boards, you have six "working edges" to cut your mullions into.
So set up for the cuts, and cut the profiles into all six edges, in assembly-line fashion. When you're done, rip off the finished mullions, and rejoint the edges of the boards.
At this point, you have six freshly-made mullion pieces, and six slightly narrower boards. So ask yourself the question, "Do I need more mullions?" If the answer is no, you're done. If the answer is yes, repeat from the beginning. Keep repeating as necessary, until you have enough mullion pieces, or the boards get so narrow that you can no longer handle them safely (at which point you get some more boards).
Here is what I attempted to explain in my earlier response. Repeat this profile on the right sight of the board and you have two muttons per pass.
Hey bones,
Unless you are making lamb chops, they're muntins, from the French muntire, "to rise up", not muttons, from the French mouton, "a sheep". Just fyi, not trying to make you feel.... sheepish...
HEE HEE, that would be a FUBAR from the english, .... well you know.Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
Thanks Steve and Bones. I think I have a game plane now.
Larry
bones and joinerswork,
Come on ewe guys, knock it off :<)
Paul
Edited 10/29/2007 3:36 pm ET by colebearanimals
Why? We just funnin ya!
cole,
You telling us to ram it? Not sure wether you meant that or if I herd wrong...
Well, time to make like a shepherd, and get the flock outta here...
That was Baaaaaaaah-dGovernment's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
Ray,
Like a hockey player? And get the puck outa here!
Bob,
Make like horse $hit, and hit the road.
