I’ve built a cherry and curly maple dresser and finished it with 5 coats of Formby’s tung oil last August. Sometime in the past day or two the dog got inside and pee’d on it. MY daughter tried to clean it up when she was wiping up the floor and she used a paper towel with a general purpose kitchen cleaner.
The lowest drawer divider and the dust cover on the bottom have a dark spot now I can add a picture if that will help. I’m not sure if its from the cleaner or the pee but I think its the pee.
Does anyone have some advice on how to repair it or if I should even try. All I can think of is sand it down and refinish.
thanks
First get rid of the pee
Bing:
You got a bigger issue than just refinishing. You don't want dog pee to remain in the dresser, and cleaning it up with a general purpose cleaner doesn't eliminate the pee. You need a product like this: http://htproducts.reachlocal.net/viewproduct.php?product=11. If it were me, I'd be building a new drawer. Otherwise, yes sand it down, treat the bare wood, and then refinish.
gdblake
Don't you just hate it when your dog becomes a woodworking critic? ;-)
clorox bleach will usually eliminate the pee odour, wash it well after with vingar and then clear water. you will more than likely should strip and refinish it. if there is any discolourization an application of oxolic acic folowed by vinegar and then water again, should do it. sometimes one has to play around to solve these prolems.
sometimes these kitchen cleaners either have ammonia or a lye base in them some where and both can alter colour of wood. oxolic acid reverses lye
ron
thanks i'll give it a try in a few min. i'd kick this dog out on his ear except the wife and kids love him and he is good protecting the house. he only has a couple bad habits
The product GDblake recommended is the real deal. I've used it on cat pee and was amazed how well it worked. It will eat up the pee and the resulting smell, but probably won't remove the stain which is likely a chemical reaction between the pee and the wood. Oxalic acid will lighten the stain, but using enough oxalic acid to really lighten the stain will lighten the surrounding wood as well. I've not found a way to fully remove dog pee stains from wood. It sounds like the stain is out of sight; I'd either build new parts or learn to live with it.
