Hi everyone. I am looking at buying a benchtop mortiser. I was wondering if anyone had any advice, pros and cons.
I looked at the Delta 14-651, the Jet JBM-5, and cant quite afford the powermatic so its really between the delta and jet. I could only look online though. Closest woodcraft is an hour + away.
Any experiences and advice would be appreciated. I have seven coffee, hall and endtables to build.
Which one
The Delta is definitely the better of the two units. Much better fence. But I do my mortises with jigs and a plunge router with a spiral up-cut bit.
I also do my mortises with a plunge router and pc micro adjust guide. However I have seven tables to build, and thats 56 mortises. Gets a little hard on the back.
Four of the tables are a paying job and will easily pay for the machine.
I'm cheap
56 mortises boils down to about $5.00 each. Too much for my budget.
choices
http://www.lie-nielsen.com/catalog.php?sku=mc_set ;-)
Seriously, I've been considering the Delta 14-651, too. It's obviously not a "high production" unit, but the reviews I've seen are favorable.
webby,
the canadian made general is what's in my shop. nice machine. as i am away from the shop, i can't give you the model # right now, but i will , if you want.
eef
Fox Pro?
One of the magazines recently did tests of the mortise machines and surprisingly gave their nod for both best and best value to the what I remember as a Fox Pro something or other. It was $100 less than the delta which they also praised.
Peter
