A new-in-box grinder wheel has surfaced in my shop, it’s fine grit (to the eye and touch), white in color and made in Israel. Despite the fact that I bought it (ages ago), I can’t remember anything about it. What’s the material? what’s the grit? I haven’t a clue. Can anyone ID it with this info, or do I need to provide more?
TIA!
The white wheel I have is on a slow-speed wet grinder. I'm not sure what the material is, however.
FG,
If it's made in Israel it's almost certainly from Camel Grinding Wheels, who are by far the largest manufacturer. The white wheels, IIRC, are intended for high-speed steel. Might be any number of grits.
David Ring
http://www.touchwood.co.il/?lang=e&id=1
Hi, Ring. Yes, it's a Camel. The label reads thusly:
Seems a good hint that it's 120 grit. forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Yes, White Aluminum Oxide, 120 grit. Attached is their spec sheet on how to decipher the labels.David Ring
Thank you, David. I'll print that out and keep it with my grinder stuff. Do you have a recommendation for a good wheel to use for reshaping a chisel?
Edited 10/14/2009 4:04 pm by forestgirl
Hi FG. I keep the coarser grits on a couple of my grinders all of the time. If you have a lot of grinding to do, rather than dip-quenching, I use one of these. http://www.littlemachineshop.com/products/product_view.php?ProductID=2725&category=It really doesn't take much honing to eliminate the scratch from a coarse wheel, but a fine one takes longer and generates more heat for heaver grinding.
Is this wheel one hump or two hump camel? I have to know.
mike
Pure dromedary, Mike, but eating it's own tail such that everything just goes round and round and round and........forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
FG ,
Sounds like Ring knows where they come from , what size wheel width and diameter ?
I use the White wheels for grinding High Speed steel shaper cutters as well as sharpening scissors and other sharp edges.
The white stones absorb the heat and in turn dissipate or wear out faster but saves your tool item from turning Blue from too much heat and risk losing the temper of the steel. They cost quite a bit more as well .
regards dusty
Hi, Dusty. See my reply to Ring for the label info. Sounds like it will be good for sharpening the lathe tools. Question now is whether the "medium" Norton wheel is OK for re-shaping the lathe tools (I'm going to turn one parting tool into a skew). "Medium" according to the site Roc provided generally covers from 36-60 grit, the lower end doesn't seem like a good idea.
Well, not doing any grinding tonight or tomorrow, so time to learn more.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
FG , When you re shape just take it slow and quench the steel in water to keep it cooler and prevent it from turning Blue.Go slow you can always take more .
regards dusty,and wet
There will probably be a code on the side made up of numbers and letters.
This site may help
http://www.georgiagrindingwheel.com/grindingwheels_basics.htm#faq2
If you see a code and you post it I may be able to tell you more about the wheel.
roc
Thanks everyone. When I get home this afternoon, I'll get some more info, check out the website roc posted.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
