After many months of construction (including the house). I’ve slowly been moving tools into so that my trim carpenter and I can work on the interior trim. All the power is currently coming from long extension cords hooked up to the machines. Here are some proud new photos of the workshop.
-Jointerman
Sorry about this... I meant to post this to the "Workshop" topic area.
Nice shop.
Are those control joints cut in the floor in the "shop helper" photo?
What is your heating system?
Dave
Yes, those are control joints. As for heating, since it doesn't get too cold here in Silicon Valley, I'll just be using a "Mr. Heater" small portable propane heater.
So you don't get freezing weather.
We do in KY and I neglected to fill the control joints in my floor for a couple of years. They got enough debris in the form of dirt , saw dust, mud, and dog hair in them that when the temp. went below freezing for a long time, the slab had no room to contract. I only got one or two wild cracks that ran out of the cut lines, but it was a wake up call to finish what should have been done. Backer rod and some self leveling caulk in the joints now and the floor is easier to keep clean.
Dave
"So you don't get freezing weather."In terms of below 32F/0C, I think it might hit that outside once in a while. However... we always whine about it being "freezing" outside when it hits the 50s. ;-).However, closing the cracks up sounds to be a good idea. What's a backer rod?
"What's a backer rod?"
For example: http://www.dap.com/product_details.aspx?product_id=356
You use it to fill most of the gap, then lay a bead of caulk or other sealant on top. That way, the caulk is less than 1/4" thick, and will cure during your lifetime. Use the next size larger than the width of the gap, so that you have to kind of squeeze it in.
You can find it alongside weatherstripping at your favorite building supply store.
What luck! I was just passing some time on the forum and now I have to go to Home Depot to get some. Thanks!
Congrats, Jointerman, a very handsome building -- it would fit right in here in the NW also! I envy you your weather. BTW, we have a Mr. Heater for the house -- keeps the living room livable when the power goes out. Great little heater, isn't it?!
I know you're proud of your "man cave".... If you can make some storage in the attic, it will payoff in the future.
Here in Texas, the housing and shed foundation slabs and footings are poured all at the same time. I was wondering about the shots of your foundation showing the footing is poured first and then the rebar and slab is poured?
Bill
perhaps you should think about telling your helper about the use of safety goggles.
Im jealous
Tmaxxx
Urban Workshop Ltd
Vancouver B.C.
cheers. Ill buy.
