I have been interested in buying a JDS Multi Router for a while and before I shell out that kind of money I thought I would check with the fine folks here in Knots.
If anyone has one, or has experience using one, and could give me a critique I’d be most appreciative.
http://www.lagunatools.com/platinum3.htm
I've used one and still prefer the standard slot mortiser.
Multi-Router...Uses a router-noisy, high rpm, limited tooling use.
To many unecessary bells and whistles. It actually makes tenons... over $3,000
Horizontal slot mortiser-typical rpm 3,000. Able to use HSS endmills and do much larger diameter slots. Regular motor,very quiet. Basic loose tenon joinery. Fast, simple! Can be used as a doweling machine or horizontal drill press and uses standard drill bits. More versatile if you could slow it down more.
$1,000 Laguna
Edited 6/3/2008 3:25 pm ET by RickL
Edited 6/3/2008 3:26 pm ET by RickL
I bought one new many years ago at less than half the current price. I have used it for normal mortise and tenons and think it works great. I have also used it for angled tenons - again with success. Another use was to make round tenons on the ends of many small "stiles" I used in making wine racks. Lastly, I have used it for lots of "special" types of cuts that come up. I find it fairly easy to set up and easy to tweak. I do think it has gotten a bit pricey (probably was) but it does a very good job for me.
I don't know about the JDS, but I have a grizzly HBM that does that job. I used it till I just purchased the Festool domino that is more flexible and much quicker. I will keep the Griz for the possible long through tennon. Very cost effective although it's gone up since I got mine. It was only 275 with I bought.
http://www.grizzly.com/products/Single-Spindle-Boring-Machine/G0540
Does the Grizzley table slide in and out and side to side?
Yes, the grizzly moves in and out, side to side and up and down. I bought one used on craigslist for $125. Mine needs a tune up but seems to be well worth the money, even for what the cost new.Matthttp://www.oldgreenwoodworking.com
http://www.woodcentral.com/articles/reviews/articles_729.shtml
Here's a review of the Grizzly G0540 Horizontal drill. It certainly can be used as a slot mortiser and you can't beat the price.
As others have said it does this task fine. I bought a regular router bit but was told afterwards I should buy cheap end-mills to use. Mined did not require any type of tuning per se, just assemply. I put mine on casters so I can roll it around. I will say that the stop mechanisms L/R and I/O are not the greatest but very functional. I'm sure the $3k units have many more bells & whistles, but this unit does what you want it to. I found (I think it was here do a search) sombody had built and posted plans for a home made jig that looked really well done that you should look at as well. Again at the time at 275, I thought it was a great deal. I would say also, beprepared for it to occupy some realestate though. Currently thats not a problem for me, but I'm relocating soon and it may have to go. BTW, here is the original link on my purchase.
http://forums.taunton.com/fw-knots/messages?msg=42061.5
Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
Edited 6/5/2008 10:05 am by bones
Edited 6/5/2008 10:37 am by bones
