I am going to be moving from the US to New Zealand, and have a small shop of tools to ship (at company expense). I’m wondering if anyone has experience or advice on the following:
1. Is it easier to buy a high wattage power converter (240 to 110), or should I figure on replacing motors on tools? For power tools, is a transformer sufficient, or do I also need to worry about the 60 Hz to 50 Hz conversion?
2. Any thoughts on protecting the cast iron tables during shipping (8 weeks in a shipping container)? Also, protection of smaller tools (planes in particular) from rust?
3. Any thoughts on protecting wood furniture during the shipping process?
Thanks much in advance for any advice,
Ian
I've moved from the UK to the US, and back to the UK from the US ten years later. The bit you're interested in, from the US to a country with 240 V and 50 Hz supply is easy. Buy a 240- 110 V transformer. All my US configured power tools-- drills, routers, jigsaws, sanders work fine. There may be some motor damage due to the cycle difference leading to slightly more rapid failure of the motor, but all my tools still work fine more than a year since I moved.
For the hand tools, planes and the like, make stout boxes and pile the tools in with plenty of foam wrapping or foam peanuts. They'll be okay and shouldn't rust significantly. It didn't happen to mine in either direction. For cast iron tables apply some furniture wax before shipping and they should be okay at the far end.
Inevitably your furniture will incur some damage no matter how well it's wrapped. In most cases the damage my stuff incurred was abrasion from the way containers are tightly packed. The only way I can think of preventing anything like that is to individually crate each item at huge cost, and even that won't absolutely guarantee complete safety.
Make sure you have appropriate insurance is the best advice I can think of. Slainte.
Ask KIWIMAC, but rust on the trip might not be all of your problem - NZ is not known as the Land of the Long White Cloud for nothing.
