Hello all,
Need some recommendations for mobile bases for jointer, tablesaw, and bandsaw. Flooring is concrete, fairly level but w/ some small dips here and there. Only mobile base I’ve used before is a Delta that I had to provide the oak 2×2’s for the rails. Handy in that only one foot pedal to operate to make it mobile, but the three-wheel system seemed a little unstable. Any others out there, or links to good plans for home-made setups?
Monte
Fine Woodworking Recommended Products
Hedgehog featherboards
The Hedgehog's unique spiral shape and single knob make it easy to set up and fast to adjust.
- Initial static pressure (in. of water): 77 - Static pressure with bag 2/3 full: 74 - Noise level (db): 80 - Disposable filter bags (5 pack): $41 - Reusable bag avail. from mfr.: $152 - Hose length (ft): 14 - Cord length (ft): 24
Armor Pocket Hole Jig Model APJ14001
The jig’s primary design feature is that the depth guide on the drill bit is set when you clamp material into the jig, so it is always right for the material thickness (from 1⁄2 in. to 1 1⁄2 in.). A color-coded system of screws tells you which screw length to use for each material thickness. A starter set of screws is included. The jig and screw system work as designed, with the exit holes well centered in material of varying thicknesses.
Makita XTR01Z 18V LXT
Power: Excellent Cut visibility: Excellent Control: Good (with standard fixed base) Bit changes: Excellent Depth adjustment: Fair
Bosch GCM12SD Miter Saw
Bosch has produced another quality miter saw. It not only fits tight to the wall; it also has the shortest distance to the miter lock. The saw’s generous miter range is complemented by its large selection of miter detents. However, it falls short in a few areas. The handle is nicely ambidextrous, but its large size may make it cumbersome for all but large hands. I also found the miter and bevel controls, including their locks, stiff. The saw is the only model in the field with no light, either an LED or laser.
Dear Monte,
HTC makes some very good units, even their universal set ups are pretty nice. I own several: two cabinet saws (Dedicated), seven universals including my jointer which is over 300lbs. I have been very pleased with them. Amazon, Coastal Tool, and Tools Plus are all suppliers.
Good Luck,
John
You can't go wrong with HTC - top quality.
I've had good luck with the Delta kit but, if I remember correctly, I had to rework it after a while as it sagged and thus dragged. Not a big problem, but I did have to deal with it.
Jerry
I have one all metal Delta 3-wheel base and 1 using wood stringers and I have never had a problem with instability. They are by far the easiest to use. I also have 2 Shop Fox mobile bases and they have been satisfactory. The Shop Foxes are better in one respect: they can be leveled far easier than the Delta style.
Unless HTC has changed their style, being that the length adjustment on the stretchers is done by moving 5/16 bolts, I would go with the JET mobile base. The stretchers are much more heavy duty and simply adjust in a socket that has a spring loaded adjustment pin. We've carried both and now carry the Jet. They come in 600lb. and 1200lb. capacity
Bruce S. Counter Sales, Tech Rep. http://WWW.EAGLEAMERICA.COM
I prefer the HTC and shop fox. I don't care for the JET, can't get it to stay put on the floor.
I have two different kinds. I have the one like you described that uses the 2x2's and they are ok. I also have the shopfox for my bandsaw and table saw. I like the shop fox, but they are more $$$. Good luck on the decision.
Hi Mil,
Just my $.02 - I bought an HTC mobile base from amazon for my Powermatic 66 saw. Instructions were horrible, showing a myriad of different designs and how to put them together - they need a seperate book for each design. Also, there were holes drilled for 5/16" carriage bolts and 1/4" bolts were supplied. Had to make a trip to the local HD for the right bolts. I actually called HTC and got a guy in the tech support department. You know what his answer was? Wow, we never noticed that! We must be shipping all of these out with the wrong bolts (he checked several bases while I was on the phone with him, all were wrong.) Now, I'm no rocket scientist, but why did it take me to point that out to them? And you know what else? No offer to send the right bolts, a free t-shirt or anything. That was a $189 mistake I will never make again.
Lee
Here is one you might like from Woodcraft.
http://www.woodcraft.com/family.aspx?familyid=5114
I did some research before I bought my mobil bases. Fine Woodworking has a very good article on these. I went with the cheaper HTC model and I cannot say anything bad at all. The setup was very quick and easy. They supply everything, no need to cut any 2x4s, just bolt together the parts. This base should work for all your tools you are needing bases for. They roll very easily and are very stable. I highly recomend the HTC.
