Hi all
My local store does not sell Denatured Alcohol(poisoned Ethanol).
Can I use Methyl Hydrate ( Methanol /Wood alcohol) to mix with shellac flakes instead?
I have some cherry doors I wish to stain and have read I should not use an oil based stain (Minwax) and should prime with a wash coat of a 1 lb. cut of shellac to avoid blotchy results. How important is it to have de-waxed flakes for a one lb. wash?
Stewie
The Sawdust shop
It is important that the shellac be de-waxed, because other finish products may not adhere well if there's wax there first.
And for what it's worth, blotchiness in cherry is, in my opinion, a perceived problem, not a real one. The blotches will even out as the wood photo-reacts.
(And further, preventing/fixing them before they happen, will have the effect of eliminating the perceived problem, but creating a real one -- when the wood photo-reacts, the spots that you evened out, will no longer be even.)
But note that this is one of those "your mileage may vary" kind of things........
Shellac dissolved in methanol will work fine, but note that methanol is much, much more toxic than ethanol, even denatured ethanol. I certainly wouldn't want to use it in an application where I would essentially be filling the room with methanol vapor.
You can get suitable solvents from the various woodworking supply houses. Hock and Behkol are two common brands.
Here's another thought for a solvent......
Go to the local liquor store, and ask if they carry "pure cane alcohol".
If they do, you're in like flint. It'll work great -- some say its the best alternative.
(But don't be fooled into buying the 151 rum -- it's not anywhere near pure enough.)(At least not for shellaccing woodwork. Maybe for yourself when the work is done.....)
"Go to the local liquor store, and ask if they carry "pure cane alcohol".
That is quite amusing for me....During the years when Rhodesia was blockaded we used that as a base for replacing petrol-it was called "Blend"- and was fine.It was made from sugar cane.
Then there was "Cane Spirit"- sort of like Vodka , quite potent and not too bad when mixed with Coca Cola.
Then there was Vodka, and a number of other spirits and liquers, all locally manufactured, that had this stuff as the base. In fact the Vodka was labelled "Smirnoff" - and exported and continued to be made right up to around 2000when the present scourge set in big time.Apart from that, the original poster could use Bulls Eye Zinsser dewaxed shellac with less bother.Philip Marcou
Dewaxed shellac is only a requirement if you plan to use an oil based poly varnish or any type of waterborne finish. Standard varnish--a nicer finish anyway--works just fine over shellac that contains its natural wax.
I understood all varnishes are oil based , so that none will adhere over wax from shellac?? Stewie
The traditional oil based varnishes will adhere just fine over shellac that still contains it's natural wax. The problem comes with the addition of polyurethane resin that creates the adhesion problems. Waterborne finishes with or without polyurethane also have challenges adhering to shellac with wax.
Thank you, Steve. I live north of Toronto , and nobody seems to carry Zinnser's 1 lb. cut or an Ethanol based product. I have some Shellac-Lacquor Thinner from Lee Valley that contains ethanol and isobutyl alcohol , so I can avoid the Methyl Hydrate I purchased from Home Hardware. Maybe I should just give it back to them. Is there any way of telling whether flakes have been de-waxed? I have 2 pkgs. ( from Lee Valley , I think ,) One labeled orange Shellac Flakes from India (looks quite reddish) and a smaller one that is quite orange ( made in USA). The finish will be an oil based varnish , so for this project , I can make my own 1 lb. cut ...wax or no wax.Stewie
Woodworking is like golf....always a new way to screw up a project/hole. :)
LV has stopped selling the dewaxed blonde shellac flakes, unfortunately. Their orange flakes are waxed. Wood Essence is usually given as a Canadian source for dewaxed shellac, but had an antiquated ordering system whereby you left your phone no. and the guy was supposed to call you back. He never did, so I ordered from the US.
In SW Ontario hardly anybody carries Zinsser Sealcoat (dewaxed shellac) but you can order it from Glidden/Dulux/ICI stores and a few others. That's probably the safest way to go anyway, because the shelf life is 2 years, and a lot of stores carry stock a lot older than that.
I use the LV thinner, though it's expensive. They sell it only in Canada, I suppose because it's difficult to find any alternative here.
Jim
Thanks for the heads up on the 2 year shelf life of the Sealcoat .
FYI If you are looking for Waterlox varnish , there is a dealer in Burlington. Exotic Woods on Industrial Drive. 335-8066.
Other posts have recommended it as the best oil based varnish.Stewie
The Sawdust Shop
Type in Methanol MSDS into your search engine & read it - that should put you off using it.
If all else fails buy a cartridge full face respirator with cartidges specifically matched to remove methanol vapour. - by the time you have sorted all of that out you may have found it easier to get denatured alcohol.
For that matter, try reading the MSDS for ethyl alcohol. People vountarily drink that stuff.
I have used methanol for dissolving shellac flakes and it has worked fine. I would heed the warnings about inhalation though, good ventilation is a must (as it is with the use of most any solvent).
A friend in West Virginia uses a shellac solvent he gets from a source in the hills there. He says it gives his projects a special shine in the light of the moon. ;-)
As an ol boy who was familiar with Franklin Co VA, I'd never use that for solvent for shellac. There is some lines one should never cross! Liquid gold!!!!!!!!!!!!!! I did see a guy on the DIY channel that made instruments that did his final polish with everclear!
Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
Edited 4/19/2009 9:09 am by bones
Yep, and aged for at least a half-hour in a Mason jar.
Leon
As an ol boy who was familiar with Franklin Co VA, I'd never use that for solvent for shellac.Yep, and aged for at least a half-hour in a Mason jar.
Leon
If you wanted to get fancy some strawberries, damson plums, or peaches help age the product as well. I was partial to damsons.
Edited 4/19/2009 11:29 am by bones
"If you wanted to get fancy some strawberries, damson plums, or peaches help age the product as well. I was partial to damsons. "How does that compare to a drop or two of Vaseline Hair Tonic? ;-)
Stewie - You don't say where you are (perhaps a country that doesn't allow sales of denatured alcohol to the public?), but I would suggest buying taxed grain alcohol (the 190 proof, or 95% stuff) to use to dissolve shellac before I'd consider using methanol (methyl hydrate).
Besides breathing the fumes (which can cause blindness, liver, and kidney damage), it will also go through your skin. Using small amounts of methanol for various purposes is OK, but the large volumes required for using it as a solvent for a finish is not. One other property that methanol has that isn't so good is a very high vapor pressure and low boiling point - you could potentially build up an explosive mixture in an enclosed shop.
Thanks for the graphic heads up. The shop is currently enclosed and I plan on keeping it that way. Think I'll give the Methyl Hydrate back to the Home Hardware. I live north of Toronto (On) and the locals just don't seem to carry either an Ethanol based product, a 1 lb. cut , or flakes. Stewie
The Sawdust Shop
I'm in Calgary and haven't found a readily available source of DNA either. I've used methyl hydrate (methanol) instead, without a problem. I don't perceive it to be a horribly toxic solvent, from my perspective most solvents are "toxic" so I treat 'em all as such. (Along the lines of "kind of pregant"...)
I just follow the same rules for methyl hydrate as I'd use with any other solvent... Follow the MSDS, maintain good ventilation, keep away from ignition sources, wear the right PPE. I've only been brushing and padding shellac. If I was spraying I'd need to step up another level of fire protection, but I'd have to do that regardless of solvent type.
Cheers and good luck,
Peter
"I live north of Toronto (On) and the locals just don't seem to carry either an Ethanol based product, a 1 lb. cut , or flakes."
Surely the locals drink alcohol (the non-denatured kind)? Or is pure-grain alcohol not legal to be sold in Canada? While I'd expect that any country would heavily tax liquor for drinking, here in the States the rot-gut "store brand" of 95% grain alcohol is about $8 USD per liter, which at least in my opinion is really inexpensive as a shellac solvent - after all, you don't need all that much, and a liter would finish several large pieces of furniture with 4 or 5 coats.
Next trip to our Gov't run L.C.B.O. for a single malt :) I will check it out. I have found a can of Shellac - Lacquor thinner whose content label includes ethanol , so that may well be the ticket. I was looking at a can of Zinsser's primer , and got a small laugh to see "clean up with Denatured alcohol (methyl Hydrate)..." Looks like some pros don't know the difference.Stewie
The Sawdust Shop
Well Stewie, depending on where you live, there is an alternative alcohol that might be available to you. In rural areas, farm supply stores sometimes carry iso-propyl alcohol for disinfecting dairy equipment. It comes in 99% concentration, which is more than adequate for shellac (drug stores also sell the stuff, at 70% and 99%, at much higher prices; the 70% has far too much water to work with shellac).
It is much less toxic than methanol (methyl hydrate), but is somewhat more toxic than ethanol (what is in beverages). Depending upon which store I go to, I can get it for anywhere from $17 to $20/gal. (Can. $$ ).
Just a suggestion for your consideration....
good luck!
Ted
Ted Thanks for the tip.Stewie
