Two years ago bought eight foot long by half inch melamine coated drawer sides with quarter inch dado into which I fit the bottom, aftr I had cut them to length and width. Now, I need to make two more drawers because I made errors on two of them. However, can’t locate this material any longer. The supplier said he stopped a year or so ago. Local cabinet shops either don’t know or won’t tell. The drawers were completely wrapped so they had no exposed edges. Any thoughts of a mail order house which could help me out?
Harry ,
You can get 1/2" Melamine and buy some iron on edge tape , trim with razor and kiss it with a formica file .
That should do the trick
good luck dusty
You can probably get the drawers already done from DBS, Drawer box systems.
http://www.dbsdrawers.com/htdocs/DrawerWeb1/1order.html
I know that they have melamine drawers.
Doug
Harry, Fessseden Hall will have it. Ask for Pete, phone is 856-768-1909.
Good Luck, Lou
Pre-made drawers are easy but might be expensive. Are the drawers deep enough that you could use Melamie shelving? That would come pre-edged and only require the dado.
