I recently purchased the 12″ Makita slide compound miter saw. My initial impression was that the rpm’s were very low (3200) compared to my 8″ hitachi at 4900.
My question is about blades for the Makita. I’ve seen blades advertised at 6000 rpm rated. How does this work with a machine that only turns 3200?
Does anyone have a suggestion for a replacement blade for the Makita?
A larger diameter blade needs to turn at lower RPM's to maintain the same rim velocity as a smaller diameter blade rotating at higher RPM's.
Circular saw teeth on manual-fed machines are engineered to perform best at about 120-140 miles per hour rim velocity.
The 6000 RPM rating is the maximum speed to safely run the blade. It will run fine at the lower speed. 3200 RPM on a 12" blade gives almost the same speed at the rim as 4900 RPM on an 8" blade.
Bill
Thanks Bill; I appreciate the education. Your explanation makes sense.
tx
I've found that the Makita stock blade aren't all that bad,
I'd use it up before replacing it.
I didn't care much for the thin kerf stock blade. It tended to deflect on compound cuts in larger pieces. I replaced it with a 100 tooth FS Tools HD Mitre saw blade. Made a good saw a great saw.John O'Connell - JKO Handcrafted Woodworking
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
John; thanks for your reply. I'm not familiar w/ FS tools. Is that the name; where does one find them?
Thanks, tx
FS Tools is a manufacturer of industrial blades in Canada. You should be able to find a source near you on their website. If you are anywhere near Anaheim I get them from California Woodworking. You won't find them at any of the hobbist suppliers.John O'Connell - JKO Handcrafted Woodworking
Thanks John; I did find their website and they do have an outlet for their products here in Boston.
tx
You won't be disappointed.John O'Connell - JKO Handcrafted Woodworking
tx,
FS Tools distributor locator is here: http://www.fstoolcorp.com/Distributors.aspx
thanks Bob. I found a source in Boston.
tx
