I’ve just purchased a Davis & Wells 20″ bandsaw and am in need of an on/off switch. Right now the only way to turn it on is to plug it in. The motor is a 220V 20Amp 3HP Dayton. Now the switch on my table saw is a black box w/ two push buttons and I believe it is a magnetic starter. What is a magnetic starter, how does it work and why is it important? Many thanks for any insight.
A magnetic switch is engaged when the button is pushed and the switch latches the way a relay latches, by way of a coil creating a magnetic field and attracting another contact. The benefit is that, if the power goes out or a breaker pops, the contact breaks and won't just start up again when power is re-established. Most, if not all, major machinery makers use these switches now.
Grainger sells things like that.
I have tried to find magnetic starters on the Grainger website but couldn't. Would you happen to have a part number? Thanks.J.P.http://www.jpkfinefurniture.com
At http://www.grainger.com I just typed in magnetic starter and got several to pick from. It took me to http://www.grainger.com/Grainger/wwg/productIndex.shtml
They probably do, as well as Greybar, Boggis-Johnson, etc. I just hate getting my eyes gouged out. I think they have a thumb sharpener in the back room.
To add to what Highfish said all the magnetic switches I have seen have built in over current protection. That is why they are sized by the motors HP or running amps.
Grizzly has mag switches for $60, that is a great price.
Edited 3/2/2006 11:09 pm ET by mudman
$60 for a magnetic switch! Thanks for the info. Grizzly does it again. I was about to pay Oneida multiples of that amount for the same thing.
Get a magnetic switch from Grizzly. Get the correct rating, looks like you need one for a 3 horse mtr. I like the magnetic starter switch on my Grizzly G0543. It is a better quality switch than my Unisaw has and was easier to wire.
You should be able to get a high-quality used mag starter with overload protection for a fraction of the cost of comparable new. I've had good luck with Southland Electric (http://www.southlandelectric.com). Plaza machinery (http://www.plazamachinery.com) should also be able to help. Many mag starters use heaters for overload protection. The heaters must be matched to the amp draw of the motor. Southland should be a one-stop shop for starter and heaters. Make sure you ask for a starter with pushbuttons and enclosure (the box), as these can also be sold separately.
Pete
Edited 3/3/2006 7:45 pm ET by PeteBradley
Thanks for the info on mag starters. You seem comfortable w/ used electrical equipment from these suppliers so I'll give it a try. I have a 220V portable IR air compressor that my generator chokes on when I try to start it. The switch on the A/C is a regular on/off switch. Would a mag switch help start the A/C when I use my generator or is there another switch that would help w/ the initial start? Thanks for your insight.
I don't think that any kind of switch is going to help with your generator/compressor situation. What you need is a larger generator. Some motors starting up use several times their rated requirement of elect. and there is no substitute for a generator or electric supply to provide it
I think you are right. The generator and the receptacle exceed the rating on the motor label so I guess there is enough juice to run the motor but not to start it. I tried this compressor on a neighbors 6.5 KW w/ similar results - I have a 5 kw.
I have an extra 7.5 KW that I would like to get rid of but that is probably to small also.
