where do I buy a single bottle of this stuff or what alternative can I use? The places I have found on the internet seem to sell to people looking for bulk.
Enco, MSC Industrial Supply or any of the other industrial supply houses should have it. Buy a small bottle, it goes a long way. I prefer the brush on type for most things.
There should be several places that you can buy online, one being http://www.use-enco.com. I know I can get it in town by the bottle too (of course I found it after I ordered online). So you might look at either a machinists tooling supply in town or in my case there is a place called Tool Peddler who has it that sells several different types of tools for metal and wood.
B.Kidd
When you buy, be careful to read the description: one type is a quick drying dye and the other (Prussian blue IIRC) is more of a grease that stays on and is used by machinists to scrape a surface.
I just ordered from Enco. Thank you
This reply is a little late, but a felt-tip marker works quite well. It is cheap and readily available.
I tried using a sharpie and an assortment of my children's coloring/painting paraphenalia. I had given up on things along those lines. I probably should have tried that. I'm not good at putting the tops back on those things so it would not have been a good fit, regardless.
You're going to have to learn to put the top back on the can of layout fluid; that stuff dries very fast. There's also a spray-on version, which would probably be more tolerant of leaving the cap off....
When I need contact points between metal parts, I use the thick ink you find a ball point pens and their refills.
Stays where it's put and won't run.
Bill
http://www.mcmaster.com Dykem is a popular brand. I often just use a wide tip magic marker.
Matt
The machinist dye is good stuff. I use the blue fast drying stuff to mark things and scribe right thru it. In the recent years I have been using black leather dye. Comes in a bottle and it dries faster than machinist blue and I can see a line even better. At half the price of the blue, you can get it from a store like Walmart. If it doesn't work for you in that application, it makes a great dye for ebonizing small pieces of wood.
Note: leather dye not sole dressing. Oh- its great for black shoes if you scuff the leather ---if you still polish your shoes.
dan
