I just saw a thread that mentioned that the vice looked like it was set up for left-handers. I didn’t know there was a difference. If there is, what is it? Right now my vice is on the left side of the bench. I am a righty – will I need to change it around to be effective? I just finished my bench & haven’t used it yet, so I haven’t run into any problems.
I think your vise layout would be considered a "right-handed" bench. Except, that is, when you plane the other direction, holding the plane in your left hand. ;-)
I am not sure how you hand a vise, but I put one on the left side and one on the right side of my bench, and find that I use the left side vise more often than the right one. I am right handed. Most of the time, I have a jig in the right one and use the left one to hold work that my right hand would be holding. I had never thought about where to put just one vise...good question
I believe it depends on what form your vices take (pun intended, of course). I think the traditional/Euro design for a right-handed worker is to have a front vice on the left end and a tail vice at the right end. That's based on a preference of pushing the work into the vice when planing, I believe. If one uses what would otherwise be a front vice across the end of the bench, that's another story.
If an individual's vice layout differs from the tradition, however, I doubt they would be visited by the Vice Squad.
I always thought it had more to do with sawing a peice of wood. A right handed person would want to hold the cutoff with his left hand so the end vise should be located at the left side of the bench end.
this thread is probably about my other bench thread.
my face vise is on the right side of my bench firstly because the left end of my bench is against a wall.
but i think it depends on what you use it for, i use mine mostly for cutting off wood with a handsaw. it means i can't hold the part that i am cutting off, but i can use my left hand to support myself on the bench. wich i think is more important than being able to hold to piece itself.
for all the other operations i do there is nothing that is hindered by the fact that the vise is on the right.
but if you use a frontal vise to handplane, then i do think it should better be on the left. but anyway a top vise would be better at that anyway, or a right-end face vise.
