I’m making a corner computer desk with a small bookcase and paper supplies cabinet tucked under the wings on each side. Red oak with a medium brown stain. I have a small spray booth, a compressor and a cup gun. I’ve used nitrocellulose lacquer in the past, and have done one small box project with brushed shellac. What would be the preferred finish? The front edge of the computer desk would have frequent contact with the heels of my hands as I type on the keyboard. Thanks
Are you open to other possible finishes? My understanding of NC is that over time oil on our skin softens the finish and makes it sticky. Growing up, our kitchen cabinets and kitchen chairs became permanently sticky after several years. I don't think shellac has this problem, but it is a thin finish and I wonder if the edge of the table will be subject to wear from sliding your hands and arms, keyboard, et cetera. You might consider wiping on several coats of a gel finish, as another option, especially if the total surface area is small.
For a desk something more durable than shellac or NC would be a good choice. I've used polyurethane in the past when I've needed something more resistant to a wet glass or wear. That said, I'm told that CAB acrylic or waterborne lacquer (e.g., Target Coatings EM6000 WB lacquer) are good choices if you want the fast drying and short time to recoat like shellac and NC lacquer. In fact, I'm getting ready to try the EM6000 -- hopefully this week.
I'd have no problem with
I'd have no problem with shellac in that context. It's limitations are with respect to alkalai cleaners, including ammonia. You'd have to leave spilled water on your computer desk for some time to have a problem that way. I'm confident that it has a basically longer life that any of the alternatives available, and if you eventually do see some signs of wair you can simply clean a bit and add a refresher coat with little fuss or mess. Probably get the job done on the keyboard tray in about as long as it would take to reboot the machine.
Two coats of shellac followed by lacquer will work fine,
SA
Lacquer over shellac? I thought that was a no-no.
I actually started spraying shellac on the first shelf box, but it did not seem to want to wet out evenly, so I shifted to lacquer for the rest of the pieces; top, second shelf box, shelves, monitor stand.
So it is safe to lightly sand the shellacked piece and lacquer it?
Shellac is a wonderful seal coat for lacquer. I wipe on two coats of shellac, sand with p320, then spray two or three coats of lacquer.
thanks for the tip. I would never have thought of wiping on lacquer as a sealer, but it makes perfect sense.
