I would like to get some opinions on the workbench approach outlined by Josh Finn in FWW #202, using a simple system of beams and boxes. I am planning a new workbench for the shop and would like to get some opinions on this approach as opposed to building a more traditional workbench. This would be my primary workbench in my shop.
-Phil
Phil,
As the robot in the movie called Short Circuit said to the farm girl. "Need input, MORE input. . .
I have gone with both styles of bench, the beams with the horses and just built a Frank Klausz traditional bench, and can speak to what works best for how I work.
What we need to know to go further is how do you intend to work? Hand work? Lots of power router work ? Windsor chairs ?
And almost MORE importantly how do you envision yourself working a year or two from now.
My quick answer is build both styles of bench; the beams and the traditional bench and a low finishing bench. I even built a little bench that I clamp to my welding table that I made just to hand cut dovetails on wide boards. ( I made it before the Klausz. ) it is the perfect hight for me to cut dovetails and has soft wood clamps. It holds the boards in the best way to transfer layout from tail board to pin board.
Several benches if you have the room.
roc
PS: The beams are versatile but can never take the place of the Klausz for quick and efficient traditional hand tool cabinet making etc. cutting dovetails and lots of hand planing.
Too much mucking about setting it up, not enough mass, lacks a way to clamp delicate drawers quickly and safely while making and fitting to cabinet, hard to get the two beams and horses so the top is flat all over . . .
I could go on and on. Doesn't mean it isn't useful for some things.
Edited 1/29/2009 1:23 pm by roc
Edited 1/29/2009 1:31 pm by roc
"Too much mucking about
"Too much mucking about setting it up, not enough mass, lacks a way to clamp delicate drawers quickly and safely while making and fitting to cabinet, hard to get the two beams and horses so the top is flat all over . . ."
roc,
i think about the building of a finn's bench but my shop's floor isn't flat...and i saw your comment about the flatness
but do you have a solution ? an ajustable height of the horses ?
thanks
here's my solution : i
here's my solution (manu31)
i built a mobile bench (the top is a little torsion box, flat) and i put my two beams on
if planning is difficult, i put my bench near the wall ; the beam is in the direction of the wall and leans against the wall
"...as opposed to building a more traditional workbench." How about something inbetween? Are you familiar with John White's New-fangled Workbench?? (Link will work if you're an on-line subscriber)
forestgirl,Do you use one of these NFWs?pat and scratch the horses for me,roc
Edited 1/31/2009 3:05 am by roc
I have one, but it's not assembled yet. ROFL!!! I bought the lumber quite a long time ago, but pattin' and scratchin' those horses took up all my time last year.
Have been getting the shop in shape, New Year's Resolution. The bench will be built soon, so as to shrink that lumber pile some. A couple of people have posted their modifications, IIRC. Will take a look at those, too, before building.
I think it may have to serve as an outfeed table, we'll see.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
NFWB
I built the newfangledworkbench and I use it every day. I have other benches but this is the one I turn to more and more. I keep figuring out new ways to use it. Yesterday I needed an easel to hold the front of a puppet theater I made for my granddaughter, so I could do some lettering on the front. I clamped a couple of L shaped practice dovetails on the planing beam, lowered it to the right height, made a perfect easel for holding a 3 ft by 3 ft piece of plywood at a slant.
Below are two old pix, first one holding a drawer, second one just a wide shot. Have since made some modifications.
